Old 07-31-2018, 05:05 PM
4RSFEDGTO's Avatar
4RSFEDGTO 4RSFEDGTO is offline
Default Twin s480 67 GTO
I figure it's time to start a build thread on my car. I haven't got alot done as far as the turbo stuff goes but now that my forward bars and motor plate are in I'm going to be building headers and turbo mounts next! Combo is 482ci IA II block, standard e-heads ported by Calvin Hill. Still up in the air on efi or blow thru. A pair of Borg Warner s480's will be hainging out front.
ID:	489295   Click image for larger version
ID:	489296   Click image for larger version
ID:	489297   Click image for larger version
Mike Bright
Special thanks to Mark Luhn at Luhn Performance for all the help
Old 07-31-2018, 07:13 PM
Got the request for plugs and replied Mike, (PY Private Message).
Not sure if the message went thru to you though. I do have parts for you.
Old 08-01-2018, 10:04 AM
Mike a good multiport EFI system not only gives great fuel distribution most of the good ones also have plenty of capacity for Data logging on board.
Cost of good blow thru and adding a Racepak and sensors either would use, to me makes more sense to go EFI.
I'm biased to the MS3-Pro and Holley offers some similar product.
Old 08-01-2018, 11:00 AM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
Looks good Mike! If I ever get your old YSI set up done, I'll be running a Holley Dominator EFI. It has a lot input/output and data logging. Also the self-tuning seems to work well.
Old 08-01-2018, 02:20 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Sweet build. I have a blow thru due to cost. If I could, EFI would be the way to go. Way more control. Good luck keep the photos coming
Old 08-01-2018, 10:58 PM
bendutro bendutro is offline
You'll be somewhere in the 900-2000HP range there. I'd want all the datalogging and control I could get in that kind of setup. Penny wise, pound foolish as they say.
Old 08-02-2018, 09:32 AM
Mike, Get my Phone Number from Mark and we can figure out how to get you the plugs and plates
Old 08-02-2018, 12:11 PM
4RSFEDGTO's Avatar
Will do Tom! Thanks again!
Mike Bright
Old 08-13-2018, 06:34 PM
PLUGS are ON THE WAY MIKE
Old 08-17-2018, 05:38 PM
Parts should be on your porch Mike.
Old 08-17-2018, 05:44 PM
4RSFEDGTO's Avatar
Yup found them at lunch. Thanks again Tom!!
Mike Bright
