Old 04-20-2018, 08:49 AM
Mike & Tina's '67 Mike & Tina's '67 is offline
Default '67 Lemans LS2 Conversion
We have a '67 lemans convertible (326) automatic and are wanting to pull it and drop in a LS2 from an '05 GTO automatic. Who has done this, what are the obstacles and what conversion kits are available? Thanks,
Old 04-20-2018, 07:18 PM
Tim john Tim john is offline
I would suggest you reach out to a company called "Speartech", they will re-work the factory wire harness for a stand alone operation in your 67. They will also re-flash the factory computer for a stand alone, removing all the unnecessary data. This is all scienced out. They are excellent to work with and have been very helpful with any and all questions I had/have. All wires are clearly labeled when you get the computer and harness back.
Tim john---
Old 04-22-2018, 07:52 AM
A good lead for the electronics were given. How about the engine mounts, cros-member, a/c hookup, cruise control, etc? any help with these and more?
Old 04-22-2018, 12:53 PM
Simple Man's Avatar
http://forums.maxperformanceinc.com/...play.php?f=423
maybe here.
be a simple...kinda man.
Old 04-22-2018, 11:38 PM
brad900 brad900 is offline
https://www.holley.com/products/ls_p...ission_mounts/
Old 04-22-2018, 11:52 PM
All the swap info you will need http://www.pro-touring.com/forums/75-The-LSX-Forum
