Fuel sender for a 67 Ventura?
My return line is clogged and as long as I'm dropping the tank to check it out I wanted to replace the inop fuel sender.
Not having much luck finding one. I did a search here and found a thread where a member found a updated part #6428629 For their 72 Grandville but I cant find that either. Any tips? Thanks. |
I sent mine out and had it redone. www.fuelsender.com.
The difference between inlaws and outlaws? Outlaws are wanted |
Thanks stevep. Any other options? Car is stuck on my hoist.
People have modified different senders to work, but I do not know what they used and what they did to it.
I found a sender from a 72 chev fullsize. I had to bend the pickup tube up a bit and bend the float arm a bit. Works good.
How did you know where to bend the float arm?
Should have taken a picture but at near the bottom of the pickup, it has a 70 deg or so bend. I had to make it more of a 90 Deg bend, the sender would not sit flush with the mount. I also had to bend the float arm to get a true empty. But in doing that now it wont register over 1/2 tank when full but will show me when it's empty. Overall not a bad deal for $53
I used a 67 Impala sender.Had to bend the arm slightly to be sure it reads 0 ohms when it is all the way down[empty].But it read full or nearly full.when filled.Only downside was it was a little floatie across the scale going around turns and stop and starts.But it worked and was only 50 dollars.The factory one is an engineering disaster as time and fuel conspire to make it quit.Usually can not be repaired...
I don't know what it is about '67 fullsize fuel senders but even Arnie Beswick has been looking for one for quite awhile.
I'm not sure what other differences there are in the 65-70 fuel senders but there are versions that have a vent line and those that don't. (generally AC cars have a fuel return line)
The basic fuel tank looks identical on all 65-70 cars (apart from the wagons) so I'd think any fuel pumps from that era can be made to work.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Found a replacement fuel tank sender for my 67 GP; designed to replace the canister type sender.
http://www.frankspontiacparts.com/us...iacpartsp3.htm |
