QA1 Springs 450lb
Hey guys, this is for a slightly used pair of QA1 springs for my 69 LeMans. These will fit any QA1 coil over system for a 64-72 A-body. These are rated @ 450lbs/in. They have 2k miles on them.
$80 FOR BOTH SHIPPED Specs : Brand:QA1 Precision Products Manufacturer's Part Number:10GSF450 Part Type:Coil-Over Springs Product Line:QA1 Coil Springs Summit Racing Part Number:HAL-10GSF450 UPC: 806990024756 Coil-Over Spring Inside Diameter (in): 2.500 in. Coil-Over Spring Inside Diameter (mm): 63.50mm Coil-Over Spring Length (in): 10.000 in. Coil-Over Spring Length (mm): 254.00mm Progressive Rate Spring: No Coil-Over Spring Rate (lbs/in): 450 lbs./in. Spring Finish: Silver powdercoated
Once you go Pontiac, you never go back |
These rears
Sent from my iPhone using Tapatalk |
Good point. These are fronts.
$75 SHIPPED!!
$70 shipped!!
$65 SHIPPED!!
$60 Shipped!!
$55 SHIPPED!!
$50 SHIPPED!!
BUMP
$45 SHIPPED!!!
BUMP
