Oil pan recommendations
Im starting to collect parts for my stroker motor and I'm looking for opinions on oil pans. There motor is going to be going into a street/strip car that could see some higher RPMs. My builder said i would be fine with the Canton 15-400 but I've noticed a lot of people are running the canton road race 15-444. Just looking for opinions on which would be a better option for a car that'll see both the street and strip.
I have a used 15-450 that will be going up for sale soon if you are interesed PM me.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
Do you need a pan for a A , B or F body car?
Be sure when you are evaluating the Canton products their listing is for "system capacity". For example the 15-450 is listed as '6 quart system capacity', by that they mean 5 quarts in the pan and 1 quart in the engine including filter. Most popular filters do not hold one quart.
It's going in an A body car. 1972 Lemans
The 15-400 is a nice pan with a single kick out on the drivers side.Clears everything well on a 1980 firebird and doesn't hang down too low.You will need a mini starter its tight.
