I'm following the advice of a few other members and starting a new thread on my adventures with 3.08 gearing. I'm heading to the track Friday and Saturday to test the new engine. New shortblock is a 466,hardblocked to the bottom of the waterpump, crower billet steel rods, CP pistons(420g),total seal rings,Chyro'd crank, balanced assembly, o ringed,new Romac SFI balancer, new ATI SFI flexplate, canton 400 oil pan with an oil temp sender. Heads have been upgraded to SD Performance "CNC 305" package, also new comp dual springs,retainers,keepers.The heads have been milled to 79cc to set engine compression at 10.75 to 1.The OF cam has been swapped for SD's OF 2.0.The torker 2 intake has also been touched up also to match the heads.Running the same 950 hp Holley,1 3/4 inch Hooker Super Comps.Rearend has been upgraded to a Eaton Posi and Dutchman 30 spline axles but retain the factory GM ring and pinion.
Dave Bisschop figures the new engine should make between 30 and 50 more hp.The shortblock is an added bonus and may contribute some "extra" horsepower over the old shortblock due to better ring sealing and a much lighter rotating assembly. I'm just wanting to see a sub 11 second pass first pass.The first goal I have is a sub 7 second 1/8th and a 100mph plus 1/8th.
Cool! Good luck and keep the updates coming.
If it's a 30 hp gain, you'll run 10.70s. If it's a 50 hp gain, you could dip into the 10.50s.
We'll see. |
Whatever you run have a blast and make it back in one piece!
Only a pawn in game of life. |
Will try to come out hook up, be good to see what the car does. Great weather ahead.
Sounds good!We are staying overnight and running Saturday too!
Traction will be the key!
what track are you running at ?
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
St Thomas Raceway Park..aka Sparta
i was hoping it was closer im on vacation in cornwall on if it was closer i would like to drive over and see you run
Fought some traction issues on a few runs but final run of the night netted 10.77 and 126mph plus.
SWEET!!!
Nice mph! Get things sorted out and it might impress people, lol. Great job.
Bitch'n!!!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
Man, you gotta love that!
Badass man!
So....30 hp gain?
All of the hard work really paid off. Could go 10.50's this fall.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
Wow...mph is crazy.
Does converter still feel tight? |
nice
