Dyno results - new vs old -- ET Predictions?
I finally got my car back to the dyno yesterday and thought I'd share my results. And if the weather cooperates, I'll be at the track later this month for the first time with this car. ET predictions being taken now! Place your bets! Dyno results feedback welcome as well.
Background: The first dyno session when I bought the car was done with a Holley DP and Performer intake. Since then I rebuilt the heads, changed to a Cliff Ruggles QJ and his modified P4B and dialed it all in with some amateur tuning by yours truly. (Timing is 16* at idle, 36* @ 3,000 RPM) The car runs really well now so I was curious to see what the numbers were. See attached dyno charts. https://www.dropbox.com/s/gg2di39l1m...02014.bmp?dl=0 https://www.dropbox.com/s/5kn0xk7a4w....2017.jpg?dl=0 Dyno runs: https://youtu.be/EKRCJmEAip0 https://youtu.be/wBh7BR87vP4 Details on the entire car are as follows: Quote:
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE Last edited by AdamIsAdam; 08-01-2017 at 10:46 AM. |
I think you needed a LOT more jet with the first combo. Your HP would have been considerably higher. You can see your graphs get shaky as the motor is going lean on that first graph. 15.0:1 is BAD!
I dyno tuned a smaller motor not too long ago. It made 306rwhp with an AFR at 14.0:1. It made 317 @ 12.8:1 You probably were giving up at least 15hp on the first combo, just in jetting.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
What is your fuel system?
The first carb is long gone. I did richen it after that session. This time they didn't have a working A/F meter. But the carb was custom built for my car by Cliff, so I'm going to assume it's not nearly as lean.
ta man, my brand new fuel system is a RobbMc 1/2" setup just installed: New 1/2" pickup (no sock), 1/2" stainless steel line through his 100 micron filter, to a 550hp pump, to a 3/8" steel line to the Qjet (with 40 micron filter). I used to sometimes run the bowl dry on the Qjet at the top of second, so far, that has not happened. Plus, the car starts up MUCH faster and easier now, both when hot and after sitting for a week. Before I had to crank it for a good 10 seconds before it would start after sitting.
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
I would have wanted to see a pull with just 1.5s rockers on the Exh side.
Did you get the ported Intake flow tested by any chance?
Why 1.5s on Exh side?
This intake is the one Cliff had SD port and do extensive testing on. There's a thread here about it... found it: http://forums.maxperformanceinc.com/...d.php?t=588973 Specifically posts to read: http://forums.maxperformanceinc.com/...&postcount=255 and http://forums.maxperformanceinc.com/...&postcount=279
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE Last edited by AdamIsAdam; 08-01-2017 at 12:47 PM. |
I say 12.50 in the 1/4 if you get traction.
Only a pawn in game of life. |
Whats it weigh Adam?
I would say 12.30's with traction. My 70 T/A with a similar set up but smaller cam and zero head work car ran consistent 12.69-12.72's. It dyno'd at 315 on a chassis dyno. Has 3.31 gears
Sent from my SM-J320W8 using Tapatalk
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15. 1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-( 1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-( |
Is it just me or do the dyno #s seem low to anybody else. I know that some dynos are conservative and some are generous, but a 469 should be making over 500lbft easily. The combo looks good except I would say the cam is very small for a 469 and you can see it is essentially done by 5200 rpm. Also, some would say the headers need to be 1&7/8" and the exhaust needs to be 3". Love the '64 by the way!
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
As for torque, 445+15% for drivetrain loss and that's about 511 lb ft. Oh, and I don't want to push the curve too far up the RPM range for a street car. Gotta be careful of that.
The Wallace Racing calculator says that your peak HP and weight would generate a 12.64 quarter mile.
I have a very similar setup that made 385hp (prior to some tuning) on the dyno and I weigh 3720 pounds. I've run a 12.75 at the track, but I know there is more in it. I've made all of 7 passes in my life and I was making the mistake of leaving off the convertor and not just above idle. The dyno numbers were made when the temp was about 70 degrees, the quarter mile time was over 90. |
I know how you like doing burnouts.....for the kids!
If your able to get it hooked, high 12's Going to run the drag radials? You looking for max ET or winning a bracket? A full tank of good fuel should help your cause. Row,row, row your Goat......... : |
Looking for best ET. I always run drag radials cause regular tires cannot provide ANY traction. It's a T&T day at the track.
Sometimes it hooks, sometimes not. My 0-60 times vary from 3.6 to ..."oh forget it" due to spinning.
I do not really have any idea where mine would be at now but 4 weeks ago had my 67 gto at a car show and ran on the chassis dyno. Had not tuned the carb or did not really check anything before the dyno pull. 2 back to back pulls it did 438 hp with 487 ft lbs torque. checked timing afterward and was only at 20 degrees advanced. Changed to 38. Went to run the 1/4 at the track 2 weeks later and found out the regulator was only at 3 lbs and would run out of gas when hitting 3rd gear with the 4 speed. bumped that up. Than ended up slowly increasing jets in the 850 double pumper each run. Started with 80's in the primary and the secondarys, ended up with 86 in primary and 89 in secondary before plugs started looking good. Of course it was 95 degrees out. Using drag radials I was running 13.1 and spinning most 1st and 2nd gear at 4500 ft. Making some other adjustments for traction but curious what difference hp and tq would be now getting it dialed in better.
