Old 12-30-2016, 10:17 AM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Default HF steel wheel date code question
A local friend of mine has these wheels that he took off of an all original 71 GTO when he put rallys on it. He has since sold the car and has the wheels for sale.
The wheels have date stamps that are different than any I have seen before. They also have a 5 digit number (21080) stamped on them and a couple of codes stamped near the lug area that I have never seen. Any help identifying them would be appreciated.
ID:	443563   Click image for larger version
ID:	443564   Click image for larger version
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 12-30-2016, 11:00 AM
carguy66cars's Avatar
carguy66cars carguy66cars is offline
I have some I will check them out today and see if they have those part numbers on them?
Lyn.
'72 400 M22 4-speed Lemans Sport GT
'72 400 4-speed Luxury Lemans
'72 Luxury Lemans 4dr. hardtop 45,000 mile car
'72 Lemans 2dr. 20,000 mile car [sold]
'73 Grandville backhalfed Drag Car
'73 Grand Am 400 4-speed
'74 Lemans Sport Coupe-4800 original miles
Old 12-30-2016, 11:08 AM
1oldgoat's Avatar
Thanks Lyn
Old 12-30-2016, 02:45 PM
Well won't be any help as the one's I have are AH code 15"x7"?
Lyn.
Old 12-30-2016, 03:57 PM
1oldgoat's Avatar
Thanks for looking.
Old 12-30-2016, 04:31 PM
This is what I have for the HF - 1971 STANDARD 14 x 6 3987808
Not sure what the 21080 is unless it was a service replacement wheel with its own number?
(the 3987808 is the part number shown for the HF)
The date not sure, possibly Aug 70?
What does it say to the left of the fill plug- 11P or UP?
710 or 71D for the first set of numbers?
(or OIL upside down )
Old 12-30-2016, 04:35 PM
1oldgoat's Avatar
To the left of the valve stem is HF. If you zoom in you can make it our fairly clearly. Bad picture taking on my part.
The other set of stampings look to me like "T10 8"
Old 12-30-2016, 04:58 PM
The Boss's Avatar
The Boss The Boss is offline
Mine are dated 12 8 in the conventional manner.
And go racin' in the street.
Old 12-30-2016, 05:10 PM
Sorry, meant to the right of the plug.
I'd say the date is probably Aug (11?) of 1970.
The T1 is probably the manufacturer.
Old 12-30-2016, 05:39 PM
Ok found mine, but not sure helps much, hard to read the date?
Name:	'72 14 x 7 wheels 001.jpg
ID:	443586   Click image for larger version
Name:	'72 14 x 7 wheels 002.jpg
Old 12-30-2016, 05:44 PM
Scott, Believe I have a similar style dated & coded (with the T) 14" wheel. Will be out in the wheel stacks this weekend & see what it is
GM used several different steel wheel manufacturers in the '60's & 70's, including Kelsey-Hayes which made many of Chevy's steel wheels, unfortunately, thus is not a K-H supplied wheel.
The typical Pontiac usage date coded steel wheels that most of us have was made by MotorWheel. MotorWheel also manufactured most of the OEM Rally II's. One will typically see the M above the year date code on MotorWheel mfg wheels. Have a feeling the wheels that date code begin with a T, like on your above pics, were made by Norris Technologys. Tough to find date decoding info on these.
Old 12-30-2016, 05:50 PM
Lyn, def hard to read, can you confirm characters & numbers are stamped to the left of the valve string? Thanks
Old 12-30-2016, 06:18 PM
1oldgoat's Avatar
Thanks Roger. I just talked to the guy who has the wheels and he told me the car they came from was a Fremont built car he thinks it was a 12C production car.
Old 12-30-2016, 06:20 PM
1oldgoat's Avatar
Roger, have you ever seen the 5 digit number like that before?
Old 12-30-2016, 06:37 PM
Not that I can remember, but on the wheels I'm thinking of, I was fixated on the T & string of numbers, wondering how to decode. Have had nearly two dozen '71 Fremont built Pontiac A-bodys as partscars & projects, will see what have in the stacks & on current partscars.
Old 12-30-2016, 06:43 PM
Ram4king's Avatar
Ram4king Ram4king is offline
I have over 20 of these wheels and not 1 of mine have those numbers yours have. Don't know what to tell you.
Old 12-30-2016, 06:58 PM
1oldgoat's Avatar
Hey Don. Do you have any idea how to read the date code?
