#61
FJ, Yes, the 2802 is great in a 10:1 400 with std. lifters. I think the 428 & 455would work well with the RAIV cam and Rhoads lifters. I'd even use a 2803 if they made one in a 455 (234/244 @ .488"/.510"). IIRC, Edelbrock marketed such a cam a while back.
Dennis |
#62
Thanks Dennis, it appears that it would give the performance of a RA IV without having to use Rhoads lifters. That's just what I was looking for. Rhoads lifters work great but are too noisy for me.
http://ultimategto.com/rest05cars1.htm |
#63
![]() Quote:
https://www.summitracing.com/parts/h...w/make/pontiac Last edited by ponyakr; 12-28-2016 at 04:05 PM. |
#64
![]() Quote:
https://www.summitracing.com/parts/c...6TAaAiDQ8P8HAQ If not, Bullet & others can get real close to whatever you want. http://www.bulletcams.com/Masters/Hlobes.htm http://www.bulletcams.com/Masters/ultradynemasters.html Last edited by ponyakr; 12-28-2016 at 04:11 PM. |
#65
![]() Quote:
#66
![]() Quote:
Dennis |
#67
![]() Quote:
"...It has been rumored that Crane makes all Wolverine Cams and this is not true. Most of the cams sold under the Wolverine name are produced by CMC. It is true that a small percentage of cams sold under the Wolverine name are produced at the Crane manufacturing facility. To complicate things further it seems that certain grinds could be purchased under the Crane or Wolverine name that are the exact same grind, and CMC or Crane depending on the grind could have produced the cam..." http://nastyz28.com/forum/threads/gu...ur-cam.264812/ CMC sells cores & finished cams. http://camshaftmachine.com/ Here's 2 Crane master lobes. HP-234/3254 290 adv .488 lift HP-244/3400 300 adv .510 lift http://www.cranecams.com/uploads/cat...ilecatalog.pdf Last edited by ponyakr; 12-28-2016 at 05:31 PM. |
#68
The 2802 is a great cam. I have problems with weird noises from the tires when I step on the gas, though....
(click on the video photo link to see what I mean) Here's the build thread: http://forums.maxperformanceinc.com/...=gramma&page=7 And the cam degreeing issue (needed a 9 position crank gear to get it exact). http://forums.maxperformanceinc.com/...d.php?t=780716 Last edited by njsteve; 12-28-2016 at 08:51 PM. |
#69
I just put in a 2802 in a 72 lemans gt convertible 455 (462) ho 9.5 c.r. ...all mostly original.. it has an auto trans...3:08 rear and has a/c power brakes etc...ram air manifolds exhaust with 2.5 X pipes... (it is in the machine shop right now) I had a crane h-278-2 in it before...pretty mild cam then...had the Harland sharp 1.65's in it there also..might try the 1:65's on it (with the 2802) after ..we'll see.. looking forward to the difference with the 2802..lot of work to do on this current resto..so could take some time to see the results
#70
B-man, SD455DJ; great info.
I've avoided this 2803 Thread because the recent Cam Install is a tame result in my 9.0:1 455. It starts and idles. That ain't right ![]() Definitely improved idle showing 7-8" vacuum in gear (was 3-4" idle in gear) Seat of pants says it feels like a 2-BBL. So this thread Assesses the 2802 is 224/234 on 114 LS, in 455s as tame at low 13's and PINGS. and the Crower 280h-10 232/236 110 LSA is a tame result in a 9.0:1 469, not sure if it Pings on 89. Still got to nail it a few more times. and the Tomahawk TC-0x? Cam 236/244 112LS in 9.0:1 (my 12.2 ET Signature) has a snot-nosed ide, 4" vacuum & unstable until warmed, with a respectable pull-away. NO PING. from this limited set, the ideal cam for Low-compression Street/Strip "455" is 233/240 with LSA between 110-114. Opens the question of LSA! What about those 104 LSAs? ![]()
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct Last edited by Half-Inch Stud; 12-29-2016 at 05:56 PM. |
#71
HIS, I wouldn't expect that kind of performance (12.2 et) from a 455 with the
2802. Maybe the discontinued Wolverine 5059 cam I mention in previous post below would be able to make that kind of power to achieve that ET. Dennis |
#72
![]() Quote:
#73
![]() Quote:
DennisJ; can you post the 5909 dur & LSA specs? |
#74
OK I''m confused....whats the hypothetic 2803?
#75
a typo for 2802. Shows you got good attention to the detail.
#76
Dennis mentions it, along with it's hypothetical specs in post #61.
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
#77
![]() Quote:
Guess it all comes down to what you want. I do not want a rough idling cam with low vacuum and more than low 22x @ .050" duration. 230+ duration cams won't make up on the top end what they lose on the bottom end with unported heads.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#78
![]() Quote:
SteelCityFirebird, There are a lot of similar cams advertised that are fairly close in duration and lift, but different LSA's. The 2803 cam I contrived is just the logical next cam in the Summit series by adding 10 degrees and 0.022" to previous cam (2803 = 224*+10/234*+10 and .466"+.022"/.488"+.022"). HIS, I agree that the 2802 is fairly mild in a 9.5:1+ 455. Hence the reason Cliff advocates the RAIV grinds for these fast piston speed motors. I think at 9.25:1 down to 8.75:1 the 2802 would work well. I have a '71 455HO motor that has only 8.4:1 and I have the 2801 (068-ish) cam in it also works well. I can run 87 octane without complaint. I've not taken it to the track, but the butt-O-meter feels like low-14's granny shifting. Dennis |
#79
Will, others,
See, I HAD installed an ancient (1970s) Isky Magnum 245/245 104 LS 104/104 LSA, that I installed 4* adv for 100/108 LCs. Well it fit all the anecdotal descriptions in this Thread. Add that it made 285-300 PSI on 3-bumps of the Compression Gauge for a 455 with 48 heads. was in my late teens/early 20's and couldn't afford slicks so it ran 12.8 in a 3850 68 GTO with unported heads. Sooooo, seems to me the CYL filling efficiency was excellent at idle+, and may continue to to play well in a 9.0:1 469. Note: Internet shows no evidence that an ISKY Magnum cam series ever exited. Yet, I know someone that FOUND my exact cam, bought it on the bet it was a winner. He put it on the shelf, showed me the cam (verifed), then years later he sold it (PY?) because Rollers became all the rage. So, that one is gone. Anyone got such a cam? |
#80
I have a nicely built 428 (.030 over 434) 400 with a small main 428 crank sitting here that is just a smidge under 10:1.
Since it's cheap to do, I'm going to toss in the 2802 camshaft and see how it acts on pump gas. |
