Old 09-20-2016, 04:25 PM
floffy's Avatar
floffy floffy is offline
Default Best big brake upgrade for 2nd gen
What is the best front and rear big brake upgrade you can do for a 72 formula with rear parking brake.
I like to hear the pro's and con's from the sets
Front 17 inch rims rear 18 inch and if possible for a decent amount of money.
Thanks,
Daan
Old 09-20-2016, 09:12 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
I put Wilwoods on my 67 and they have been great. I did have a number of issues during the install but nothing to bad.
http://forums.maxperformanceinc.com/...d.php?t=512542
67 Firebird Convertible
Old 09-20-2016, 11:33 PM
We make a nice drum-in-hat rear, goes well with the 1LE fronts.
Uses a better caliper than the S10/LS1 rear too.
Old 09-21-2016, 12:10 AM
floffy's Avatar
Scarebird,
I updated my 10 bolt with moser 7900 big ford bearing ends and 30 spline axles.
Will your kit wotk with those upgrades too?
Old 09-21-2016, 09:48 AM
The best is to use the AFX spindle and a C5/C6 brake kit. Choose a brake setup that has a bracket that fits your rear housing so you have a matching set. Wilwood has the most available options for rear brake setups, but there are others.
Old 09-21-2016, 09:52 AM
Originally Posted by floffy View Post
Scarebird,
probably not.
Old 09-23-2016, 06:55 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
That afx requires new control arms as well because the spindle has a different KIA, you will be in it $$$$$$$$$$$$$$$
Better off with a nice 13" front kit and a D154 or Dyna lite rear kit since you have the ford bearing
www.pro-touringf-body.com
Old 09-26-2016, 10:14 AM
The question was what the 'best' is, and that no question is the best, no cost consideration. I've seen that setup out perform full custom chassis cars. (and it's less than that config)
But you are correct, the more affordable approach, if braking is the key upgrade you're trying to obtain, would be to use a 13" setup.
IF, you DO upgrade the brakes, and use the OE control arms, those things will flex like heck. They flex with the OE brakes and skinny rubber. I would strongly recommend the aftermarket control arm upgrade even before a brake upgrade.
I'm sure you will agree, with a decent brake upgrade, cowl deflection is also a concern, so the braces would be a good idea too.
Old 09-27-2016, 03:06 PM
floffy's Avatar
Can you explain to me what " cowl deflection " means?
I'll probably go for the wilwood dynalite billet 4 piston callipers and 12.19 rotors front and rear, would that be a good choise?
Old 09-27-2016, 03:20 PM
On a uni-body car, the cowl is a structural support, and the front frame section attaches to it. Under hard braking, the front frame rails want to push up and back, towards the cowl, and this causes that cowl 'box' area to distort. Best I can describe it. But you can review simple structural design and chassis books, which should give you a more clear picture.
The Herb Adams handbook is a great starting point for anyone who wants to build a 2nd gen for performance handling.
There are braces, sometimes called 'G' braces, that create a triangular framing, from the cowl to the front upper control arm mount point, which drastically reduces cowl deflection. Herb Adams made them in the 70s, and Pro-Touring F-Body makes some these days. Believe others make them too.
Here's a thread on Pro-Touring.com that might be of some interest:
http://www.pro-touring.com/threads/1...or-extreme-use
That's a fairly new thread, search there, and you will find a bunch of other mods and discussions regarding 2nd gen frames, suspensions, etc.
Old 09-28-2016, 08:58 PM
SMW SMW is offline
Ram Air Restorations has a better design for the Y-bar where it attaches to the cowl.
Old 09-28-2016, 11:16 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Do you make a kit that converts my 71 with 78ish rear discs to the better drum in hat parking setup. The stock rear caliper/parking brake setup sux.
tnx
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 09-28-2016, 11:43 PM
Yes, it will work - even better with the stock disc axles.
Old 09-29-2016, 06:26 AM
pro-tour79's Avatar
LOL who do you think makes those, so they are not a better design they are the exact same!
Old 09-29-2016, 06:40 AM
pro-tour79's Avatar
for the front these are a waste of time, don't focus on the number of pistons and rotor diameter, do the math look at the total size of the piston area and also the thickness of the rotor
Stock single large piston calipers have more clamping force than the Dynalites (you only count 2 of the 4 pistons as they have an opposite force )
Your stock rotor is 1" thick, the Dynalite kit uses an .810 thick rotor.
Dynalites in the rear are fine as long as you don't have C-clips anymore.
