Hazards come on but wont flash, signals work
Need some help here before I loose what hair I have left.
Replaced the whole cars wiring with American autowire and have all lights working (except hazards) after finding out the signal switch was bad. After replacing the signal switch I got the signals working but now the hazards will come on but not flash?? Tried replacing flasher but same deal. I also have an issue with the dome light not coming on with the headlight switch but comes on with the door switch. Dont think the 2 are related but not sure. Only thing I can think of is the new signal switch is bad. Any help would be much appreciated
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes. https://www.facebook.com/media/set/?...7567172&type=3 |
I assume you changed the correct flasher being there are two. One for the signals and one for the hazards?
At least that's the way it is on my car. |
There are 2 flashers on your car & the one at the fuse block is for the flashers & the 1 under the dash is for the turn signals. As far as the dome lamp not coming on you could have a bad headlight switch. You should feel the wires rubbing in the switch as you turn it to turn the dome lamp on . If the switch is bad which they do burn up the dome lamp part a lot. Try a new headlamp switch.
Sometimes you can't see the trees for the forest and need another set of eyes.
I think the headlight switch just makes a ground for the dome lights when turned all the way counter-clockwise.
Since they work with the door switch, it is getting power. Not sure how the headlight switch is grounded, maybe missing a ground wire on switch or dash? I think the wire at the switch is white, try grounding it and see if the dome light comes on?
Check to see if the wire for the dome lamp is not backed out of the switch to. It may not be making complete connection.
