AC pressures make no sense
I charged my AC system last night and left the gauges hooked up see if the system equalized. I got busy doing other things and went out this morning to check the pressures. I have 97PSI on the low side and only 10psi on the high side. Any idea what could cause this?
Well, I feel pretty stupid. I went out and tapped on the POA valve and expansion valve and nothing happened. As an after thought I checked the fitting from the manifold hose to the car. It turned less than 1/4 inch and the pressures equalized. So far, so good. Test drive tomorrow.
