Mobil 1 ATF in transaxle?
Any reason I shouldn't or can't use Mobil 1 fully synthetic ATF in the transaxle, other than cost?
Chuck Seattle |
Bump
I have always used regular Dexron III in the transmission. I run 75-140 synthetic in the differential
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
I would not use synthetic in an older automatic transmission as the synthetic fluid seems to be more prone to leaking.
The difference between inlaws and outlaws? Outlaws are wanted |
You can do it, but you don't know how the old seals will react to it until you run it for awile. I don't run synthetic oil in anything built before 1990 unless it came from the factory with it. If 1 of the many seals in the transaxle doesn't react well to it you will have a leak, or performance issues.
I don't like to run experiments on my dime for the oil companies.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
