Old 06-01-2016, 11:10 AM
Elarson's Avatar
Elarson Elarson is offline
Default New AllPontiac Aluminum Block
This particular one is destined for the Boss Bird. It will save weight and have replaceable sleeves so we can fix cylinders at the track if needed.
Look closely at the pictures....what's different (compared to other aluminum AP blocks)? Hint: it will be much stronger.
Eric
Name:	aluminum block 1.jpg
ID:	429644   Click image for larger version
Name:	aluminum block 2.jpg
ID:	429645   Click image for larger version
Name:	aluminum block 3.jpg
ID:	429646   Click image for larger version
Name:	aluminum block 4.jpg
Old 06-01-2016, 11:23 AM
slowbird's Avatar
slowbird slowbird is offline
Looking good!
Old 06-01-2016, 11:26 AM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
I never seen an aluminum block up close and raw, but looks like a lack of freeze plugs and a much beefier lifter bore area.
Old 06-01-2016, 11:32 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice!!!
BTW, looks like solid water jacket.
What does it weigh?
Go fast, see Elvis!
Old 06-01-2016, 12:46 PM
Don 79 TA Don 79 TA is offline
wow
nice piece for sure
Old 06-01-2016, 01:03 PM
Anderson Port Development's Avatar
Anderson Port Development Anderson Port Development is offline
Eric
... somebody wants to move lifter-bores !!! ... WOO HOO !!! ...
Old 06-01-2016, 01:05 PM
Elarson's Avatar
Nice!!!
What does it weigh?
Winner!!
Haven't weighed it yet....expecting maybe 20-30 lbs heavier than the jacketed aluminum block.....still a good savings over iron.
Eric
Elarson's Avatar
Nope...no need with our billet Tunnel Port heads.
Eric
Old 06-01-2016, 01:09 PM
Elarson's Avatar
Yes, the backbone down the middle of the lifter valley is much beefier.
Eric
Old 06-01-2016, 01:11 PM
mgarblik mgarblik is offline
I will weigh it with a bathroom scale in a couple of days and post. It's heavy for aluminum, but I can pick it up and move it around by myself. I don't think I can pick it up and put it on a bench by myself. I am guessing 140-160 lbs. I will let you know.
Old 06-01-2016, 01:30 PM
Eric
.... I wasn't talking about you guys .... 😉
Old 06-01-2016, 01:31 PM
Elarson's Avatar
Ahhh....gotcha. Lots of possibilities exist.
Eric
Old 06-01-2016, 02:02 PM
slowbird's Avatar
Eric
Do they come that way (beefy backbone) or did you guys have it made that way?
Old 06-01-2016, 02:10 PM
Elarson's Avatar
Special order with the solid water jackets, beefier lifter valley, cylinders not bored as deep into main webs, 9/16" head stud threads, 1.00 lifter bores for bushings, 55 mm cam tunnel.
It basically has everything you'd get in a billet block except skirted mains.
They cast (4) of them and I think they are all spoken for. I'm pretty sure they'd make (4) more if the orders came in.
We'll have some more machining to do ourselves....adding our front oil feed hole, machining the decks for sleeve registers, etc.
Eric
Old 06-01-2016, 02:32 PM
Very Impressive block and the Tall "Backbone" configuration will make the aluminum block VERY STRONG.
Being able to have registered sleeves and a solid block will make the block/engine potentially competitive with other brands.
Old 06-01-2016, 03:31 PM
smokey 1978's Avatar
smokey 1978 smokey 1978 is offline
Send a message via Yahoo to smokey 1978
Price for this block?
Albert Marquez
1965 GTO TWIN TURBO DCI RA5!
Old 06-01-2016, 04:25 PM
Elarson's Avatar
Call AllPontiac about that. Now that they've finished the first batch, they should have a better feel for the pricing for future runs.
Eric
Old 06-01-2016, 08:01 PM
455firebird1969's Avatar
This is what the standard IA-IIA looks like for comparison. That is one massive lifter valley backbone.
Old 06-01-2016, 08:05 PM
The back of the block, with the water jacket openings.
Old 06-01-2016, 08:19 PM
Any changes to oiling scheme?
