Old 05-18-2016, 07:01 PM
crm318 crm318 is offline
Default How do you guys measure the tubes, idle bleeds and orifices of a Q-jet?
I have 3 quadrajets that I would like to extensively build, but I need to know the I.D.s of all of the various tubes, air bleeds, idle and orifices with in the carbs to get the proper parts/combination. What tools do yall use to measure these
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 05-18-2016, 07:04 PM
Old Man Taylor's Avatar
I use pin drills.
Old 05-18-2016, 07:41 PM
Yup, pin drills.
Old 05-18-2016, 08:23 PM
Firebob's Avatar
Firebob Firebob is offline
Yup, and a mic.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 05-18-2016, 09:41 PM
frankyboy455 frankyboy455 is offline
same here, pin gauges.
Old 05-18-2016, 10:09 PM
MrWrestlingII's Avatar
MrWrestlingII MrWrestlingII is offline
I used a cheap drill bit set from Harbor Freight and a dial caliper
1970 GTO-vert, 461, eheads, stump puller, m20, 3.42
Old 05-19-2016, 12:43 AM
I said pin drills. I use the drills to modify the holes, but I use pin gauges (as mentioned above) to measure them.
Old 05-19-2016, 10:31 AM
"QUICK-SILVER" "QUICK-SILVER" is online now
Default All of the above
And...a few of the folding pak torch tip cleaners. The files are in drill size and the starter tip is slightly smaller. Really handy to clean and ream down tubes, without pulling, if they don't need opened up a bunch.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 05-19-2016, 06:55 PM
Well, I had better get me a set. Thank you guys!
Old 05-19-2016, 11:36 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Do you have Cliff's book?
Shut it off
Shut it off
Old 05-20-2016, 08:17 AM
David Jones's Avatar
I ordered mine from Sears.
Old 05-20-2016, 10:36 AM
beertracker's Avatar
beertracker beertracker is offline
Snap on Tool makes a good set of carburetor numbered drills. I am not a Snap on Tool dealer! If you want accurate numbered drills expect to pay. I have the Harbor Freight set and drill measurements are off by up to .007" depending on the diameters measured with a caliper. Do as your budget dictates.
