Old 03-31-2016, 01:16 PM
ry57pont's Avatar
ry57pont ry57pont is offline
Default cam break in lube?
is engine assembly lube the same as cam break in lube?
1970 gto (4spd) 462 500 hp
11.940@114.21 / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 03-31-2016, 02:24 PM
Mike Davis's Avatar
What type of cam?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 03-31-2016, 02:30 PM
grandville455's Avatar
torco mpz cam lube
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 03-31-2016, 10:31 PM
wts69bird wts69bird is offline
Brad penn straight 30
Old 04-01-2016, 10:06 AM
ry57pont's Avatar
Originally Posted by Mike Davis View Post
What type of cam?
Factory hydraulic chevy L-79 in a 327. just didn't know if there was "special" cam break in lube on initial startup, or will "normal" assembly lube work?
1962 corvette
Old 04-01-2016, 01:21 PM
Mike Davis's Avatar
Normal assembly lube should be fine. Fact is nothing is going to remain in place with a little heat and oil pressure.
Old 04-01-2016, 01:35 PM
77 TRASHCAN's Avatar
Flat tappet cam lube needs to have moly in it.
Shut it off
Shut it off
