Hi all,
In the production instructions box on my build sheet does anyone know what the 'SR' stands for? My car has an 'SR' block, it has the correct casting number 9773155, is there any connection?
Ron 64 GTO convertible, gone but not forgotten 76 CB750K 72 CB350F " why yes, I am old school, so what?" |
Ron, I believe the SR stands for Special Ratio. I have several examples of Pontiac-plant built 1964 GTO with 3.90 gears, and they all have the same SR PN 174 175 in the Production Instructions box, and AXLE 39 10 APP in the bottom box.
Mike
1959-1980 Pontiac Window Sticker Reproductions : http://www.pontiacwindowstickers.com My Bio: I am currently writing articles for POCI's Smoke Signals magazine and enjoy promoting and discussing the history of the Pontiac Motor Division. |
Thanks Mike, that never occurred to me.
I have a 1965 GTO and a SR casting # of 9773155 also. I thought SR stands for SERVICE REPLACEMENT?
It's my understanding that they are the last 3 digits of the front and rear Heavy Duty or Handling Shocks as in 3178174 and 3178175. The other choices would be Standard or Trailering 3186908 and 3186909 or Superlift RH 3178552 and LH 3178551.
More pictures of my former Goat: http://www.barrett-jackson.com/appli.../w_search.aspx My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K And in the 2008 Scottsdale auction, Lot #960 - $80K Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900 |
I believe John V. would be able to offer more insight into this. I'm not certain, but I don't believe SR would stand for Service Replacement block. I can't imagine why corporate would specify a service replacement block for a car coming down the assembly line. I was comparing different Pontiac plant 1964 GTO build sheets I have, and the ones with the AXLE 39 10 note always have the same message in the Production Instructions.
I agree with riggsjr. He makes too much sense. Back in the day when we blew up the original engines, we went back to our local Pontiac dealer, gave him a song and dance about a bad engine and hopefully he'd order a new one from the factory because he had none sitting around, hence the SR. I'm not saying that the original engine was stamped SR, just the "service replacement" engine. Just my 2 cents worth-
Guys, I'm referring to the "SR" on the build sheet only, the topic of discussion here. If an engine needed replacement, then yes, a service replacement block may be used if the engine could not be repaired.
I can't imagine why Pontiac would code a build sheet for a service replacement block on a car that hasn't yet been built? The AXLE 39 10 APP reference was for 3.90 gears. The only way to get this ratio was with posi and metallic brakes, and those codes are shown in boxes 71P (3.90), 692 (metallic brakes), and 703 (posi). Mike
Replacement Blocks were supposed to be stamped SR by the Dealer changing the Block.
SR on a manifest typically meant a Special Request or Special Ratio in the 3.90 axle case. Tom V.
![]() Quote:
At the time the build sheet is printed the car hasn't been built. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
![]() Quote:
"Tagging" is the means by which an employee had dibs on a car, either because they ordered it or because they were going to receive it after it came out of company car use (either as a development car or a PEP type vehicle). More famous example shown below. K
![]() Quote:
MikeNoun-You're right, I got off the track-SORRY!
I see it has the "9" in the tranny box...also for the 3.90 gear speedo drive. Sounds like an interesting car at the very least!
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
SR=front springs
PN=rear springs 174=front shocks 175=rear shocks |
