Old 07-16-2015, 06:57 PM
wd45gto's Avatar
wd45gto wd45gto is offline
Default crane fireball cam
any body run or have run a crane fireball h 294b cam. 294/304 .488/.508
have a 421 4 speed or maybe a 400.
just wondering if it a good go fast cam
64 tempest wagon 421 gasser
Old 07-16-2015, 07:31 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Yes, one of the best street performance cams ever! IMO
Go fast, see Elvis!
Old 07-16-2015, 07:56 PM
J.C.you's Avatar
J.C.you J.C.you is offline
What I am going with in my 64 GTO tri power 389 project.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 07-16-2015, 09:26 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What are the .050 numbers?
Old 07-16-2015, 10:07 PM
PAUL K's Avatar
234/244 112 LSA
Go fast, see Elvis!
Old 07-17-2015, 05:50 AM
455firebird1969's Avatar
I bought a used engine that supposedly had a crane fireball cam in it back in the seventies. It was a 400 with a torker intake. That thing didn't have much off idle, but up above about 4000 it pulled hard.
Old 07-17-2015, 09:36 AM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
This may sound sad to some, but have had the same cam in my street 69' F-Bird for ~ 30 years (put in 85' I think). Runs 11.60's @ 117.
I feel there is more room to optimize to achieve a lower ET if / when I get off my duff.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 07-17-2015, 10:26 AM
PAUL K's Avatar
I don't know your combination but I don't think 11.6 @ 117 sounds bad at all. There are a lot of guys going slower with hydraulic rollers.
Go fast, see Elvis!
Old 07-17-2015, 11:20 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Is this cam from the Fireball Roberts era? Or just marketing?
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 07-17-2015, 11:36 AM
I recall the 294 B was desired over the 294 A.
In the 80's I got a used 294 B and with 1.5s, and a Torker I, it ran okay in my 428 TH400 & 3.90/4.11 rear.
Next step was the ISKY Magnum 320 HYD with 252/252 @ .050 : what an amazing full range cam on the 428 @ 455. I attributed the amazements to the 104 LCs.
Tried customizing a couple Ultradynes with 104 LCs. And installed with 4 deg adv.
--> Does anybody run Street/Strip with 104 LCs?
Last High-Compression step was the Lunati 30705 (SPC2-320) with 245/255 @ : best off-idle I've felt on the 455 ran 11.0 ET, 123 MPH with ported D-port iron. Simply the best off-idle, cleanest plugs, temps, manners, performance from my efforts. Other folks have their favorites, perhaps same or better, maybe worse.
Since gone to low compression & cam in Sig with last outings showing 12.2ET in 3850 Lb on 89 Octane.
It's all in the Signature.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 07-17-2015, 11:52 AM
pontiacreddz pontiacreddz is offline
I used a Crane Fireball cam in a 1979 Trans Am a 400 4 speed with a street dominator Holley intake 750 Holley carburetor 4:11 rear headman headers car had a great rump to it and ran 11:70's and could drive it any where
Old 07-17-2015, 12:23 PM
mgarblik mgarblik is offline
That series of cams was developed in the late 1960's early 1970's. I think Fireball Roberts had met an untimely end in a Ford Stock Car a few years earlier. Not a bad cam choice. Much better stuff was devevoped by Harold Brookshire around the same time. If you have good heads, it would benefit from some additional rocker arm ratio from a 1.5. If you already have one, I would run it.
Old 07-17-2015, 05:44 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Nice cam in a 455, it will also like at least 10 to 1 compression.
I've known several folks to use that cam in 455 builds with well prepared iron heads, and all of them ran well into the 11's with their cars...........Cliff
Old 07-20-2015, 11:40 PM
NeighborsComplaint's Avatar
Those specs sound very similar to the current Crane HIT 284281 I have in my 455.
Old 07-21-2015, 10:38 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I loved the old Fireball in my 69 Judge. Back in the early 80's nobody could get past me. If I could find another one I'd use it again.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
