Looking forward to some pictures. Thanks Jeff!
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Sorry, Work and almost 2 feet of snow prevented me from making it to the storage stash this weekend, Both the car and the spares are about an hour from my house. Hopefully this weekend,
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
oil pressure regulator
Hi Cammer-6 can you please give me some enlightenment on your oil pressure trick. Thanks your help is greatly appreciated.
I know its been a long time sense I said I was going to get pictures of the 2 HEI's I have. I pulled the 69 Bird out Sunday it has the Later Large style with the shorter Cap. Here are a couple of pic's, you can also just see the Small SBC Fluid Dampner, and the accessories that had to be moved forward 1 1/4".
2nd try at pic's
Jeff,
Was that Fl Damper a direct fit or did you have it cut?
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
If he used a chevy crank it probably direct fit to the crank (isn't it a stroker?). Otherwise the OHC crank either has to be turned down or the balancer opened up.
I'm curious to know the actual answer
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
Yes the engine is a Stroker with a GMC 292 Crank, the Small SBC fluid Damper is a direct fit to a 292 crank. To fir the stock OHC-6 Flywheel you need to open out the ID of the Flywheel to match the 292 Crank.
I hope to undig Tom Langdons OHC-6 to get some pic's of the large HEI on it.
I forgot it was a Stroker. Thanks Jeff.
I wish you would pull out and do a full engine-stand mock up with that engine, would love to see it all assembled
That's the plan later this month, I am finally recovering from both the Fire next door and all the damage it did to our house, and what ever bug I picked up in Japan this spring. I was sick for over 2 months, they never did figure out what it was. Just getting my strength back now.
