Old 06-02-2015, 03:19 PM
Speargun's Avatar
Speargun Speargun is offline
Here was my solution to avoid stock/solid/plate mounts.
Polyurethane to dampen vibration and a captured bolt to keep the engine from going anywhere if the poly failed. That said, build at your own risk. My car is in the body shop & these are untested so they may be total crap, but I think the theory is solid.
Speargun's homemade engine mounts
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 06-02-2015, 03:24 PM
Speargun's Avatar
Originally Posted by stroker461 View Post
Im just curious, its probably a stupid question but will hard block help this at all? cuz my block is filled to front water pump holes on front of block, its gunna be a strictly race engine due to the hard block and dont think cam is gunna be to streetable lol
Hard block to the bottom of the water holes should be just fine on the street. Mine is filled the same and will see mostly street time.
Your cam, on the other hand.........
No!
Do not try!
Do! Or do not.
Old 06-02-2015, 03:46 PM
stroker461's Avatar
stroker461 stroker461 is offline
Yea cam is 277/288@50 with 485/471 lobes with 1.65 harland sharp rockers which everyone says they actually measure out more so ya can do the math lol
Old 06-03-2015, 08:54 PM
gkinch's Avatar
gkinch gkinch is offline
I cracked my 455 block while using solid mounts went to motor plates and no problems with block cracking anyway!
Gene Kinch
1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116
1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108
1971 GTO 400,t400 3.23 10 bolt all original 14.41@96
1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85
1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction)
1979 TA, 400/ 4 speed all original needs restoration.
1999 Trans Am LS1
Old 06-03-2015, 10:43 PM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Default Under 1.4 60's would be awesome.
If I can get motivated to put my car(65GTO) back together, I would like to replace the solid mounts with a Mid plate and some "ears" on the front.I would like to use aluminum for the plates/ears and have the attachment brackets on the frame welded on. Any suggestions? Other mods are 5,000rpm 8"COAN, little bigger cam and 200lb diet.
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 06-04-2015, 12:35 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Nice to see you here Phil!!
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 06-04-2015, 08:51 AM
60man's Avatar
60man 60man is offline
They say it helps??? If it will crack cast iron it will breake the filler. IMHO..
The more power you make the more stress you exert on the block at motor mount pad.
Just saying. At least run a front plate.
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 06-04-2015, 09:12 AM
janderson's Avatar
janderson janderson is offline
Consider installing some type of limiter to control longitudinal movement once you eliminate the mounts.
What we did on the '78 with front and mid plate.
Old 06-04-2015, 09:22 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Why couldn't you run a front plate and mid plate and use a solid motor mount as a limiter?
Either a solid mount on one side or both sides.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 06-04-2015, 11:21 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Does anyone else use a limiter on both sides? I just have one on the passenger side and thought that was sufficient.
Old 06-04-2015, 03:17 PM
GOAT490's Avatar
Talking
Hi Jack! Thought if I got involved in posting it would probably get the juices flowing.
Now, back to the thread!
PHILLYGOAT
