Old 02-10-2015, 09:51 AM
jstoelk625 jstoelk625 is offline
Default '69 clutch and brake pedals
Howdy folks, can someone please post a picture or 2 of an original, correct set of pedals. I've seen several representations which turn out to be 67/8 or Camaro, but nothing definitive as 1969 FB. I've been told that 69 is different from the others and the others have to be tweaked in order to work. Hopefully someone can help out and clear up the confusion. Thanks in advance.
Old 02-10-2015, 02:09 PM
Here is my June 69 Norwood built Firebird. It came with the GTO style clutch and brake pedal pads.
The car has the decor group so the pedals had the stainless trim (not on the gas pedal though, maybe it was changed at some point) and like GTO's the parking brake pad switched midyear from ribbed with trim to a "brake" labelled pad without trim.
In this photo I've replaced the brake and clutch pads but the originals were the same. Most sources say a 69 Fbird should use the chevy style pedals with the chrome trim in the center but every 69 I saw over the years in boneyards was like mine.
1969 Cat (3 Cvt’s & 2dr ht)
1969 Bonnie Cvt & 2 wagons
Old 02-10-2015, 02:13 PM
Here is a pic of the original pads before I replaced them.
Name:	june 30th 2014 011.jpg
Old 02-10-2015, 03:00 PM
nashcar nashcar is offline
Mine is a Lordstown car around early March build, the pedals are the same. You can see pictures by clicking on my Firebird site in my signature.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 02-10-2015, 06:38 PM
Held for Ransom's Avatar
Units are different.
http://www.forums.maxperformanceinc....d.php?t=560245
Old 02-12-2015, 11:26 AM
rtanner's Avatar
rtanner rtanner is offline
ive been told they are different also, but i do beleive they will all interchange, and work properly, correct me if im wrong, i actually had a 69 parts car when i converted mine to 4sp, but before i got it i was going to buy a set of camaro pedals and put in it
Old 02-13-2015, 07:17 PM
vetty vetty is offline
If you are lucky enough to find a set of original 69 bird pedals then use them but they are becoming crazy expensive. I ended buying a set 69 camaro clutch brake pedals and nodded my auto bracket to accept the camaro pedals. Wasn't easy but a lot cheaper to buy and get 4 spd pedals in my car.
1969 Firebird OHC 6 Sprint
Clifford Intake, Clifford Shorty Headers, Crane H320 Custom Grind Cam, Edelbrock 550CFM, T5 5 Speed Transmission (.63 OD), 8.5 10 Bolt Posi 4.11 Gears.
Old 02-14-2015, 03:23 PM
Jeff Hamlin's Avatar
Arrow FWIW
Here are some images of a Pedal Assembly I salvaged from a 1969 Firebird OHC/SPRINT.
They still wore the correct factory paint/dip.
Old 02-15-2015, 08:46 PM
Thanks folks, I think that I've finally got it. A friend came by with a photo of his brother-in-laws original 69 (bought new by his folks) and the clutch/pedal assembly looks just like the one posted by Jeff. Now all I have to do is find one.
