Your car sounds very similar to mine currently. Those Rhoads must really calm that 60919 down...
We also have the same taste in vacuum gauges. Ha! Mine pulls almost exactly the same vacuum as yours. How much of a difference was there going from the 2802 to the 60919? You used rhoads and 1.65 rockers with both?
1970 GTO 455HO Convertible M40, Sierra Yellow, Saddle Int, Tan top. PDB, PS, PW, A/C, Rally Gauges, Hood Tach, Spoiler |
Not a huge difference between the 2 cams. I think the 60919 makes power a few revs higher, but feels like it makes a bit more up there too. I run a stock type converter, so I really havent taken full advantage of it yet. Cliff also told me if I was making less than 9.5:1 compression I would be better off with the 60243. Im right at the 9.5:1 cut off. I think he said that the 60919 would be even better closer to 10:1 compression, but Im not confident enough with my tuning skills yet to try that with iron heads down here in Florida.
Any idea what your cranking compression is?
I'm .030 over on mine, and the piston actually is an RCH out of the block on mine because they align honed the block way back when. I know there is variance of chamber size on 96s. When I ran mine through a calculator using my measurements and assuming a 96cc chamber I got 9.7:1 static.
Sorry I dont remember the cranking compression. It has been a while since ive even messed with the car at all. Im .30 over on mine too. But from what I have read many of the 96 heads are even into the 100cc+ on the chamber size, so its a guess for me at best. Thats something I really want to do before I finish the build this time. It is the only variable I dont really know right now. Im zero decked.
I logged in to PY tonight with the intention of asking this exact same question, although I'm running slightly different equipment. I believe I have higher aspirations for power levels... I'm looking to get more competitive/serious at the track, while maintaining streetability.
I've been debating several weeks now between replacing my 6X (mild-ported) heads with aluminum heads, or changing up the cam package on my 467. Lot of $$$ to upgrade to aluminum heads. And then there's the dilemma of deciding on which heads. And then you want to get a good set of headers to go along with whichever port you decide on... ugh. Decisions decisions...
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
Matt you may want to look into a power adder as well. Roots/procharger/turbo/nitrous. Seems like they arent much more than new heads but add more like 100-150hp up. Some claim to even double their hp. Worth a read anyway.
Allow me to be the bad influence.
Oooooooh! Nice!
Not really, Mr. Marshal woohoo's engine is much nicer. He applied the laws of overkill and I applied the laws of just kill and get it over with.
Looks sexy to me!
Im curious, does anyone know the flow numbers of a stock 87cc Edelbrock? |
Hot Rod mag did a write-up on the 87cc round port CNC version with out of the box flow benching numbers. http://www.hotrod.com/how-to/engine/...r-pontiac-v-8/
The 72cc version flows a little better. |
Yes, I used the 72cc heads & gained about 10cfm over the 87's.
Carburetor building & modification services Servicing the Pontiac community over 25 years |
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
I am going to get my engine pulled here pretty soon and do some measuring to see what heads I can actually use. Im pretty sure the builder told me it was zero decked, but at this point its been so long I really dont rememer for sure. I dont know that I would be able to use 72cc heads on mine. And it is 99% a streeet car. Im beginning to wonder if I should do some rotating assembly upgrades first. Get a forged crank, H or I beams, and some good Ross pistons. But 2 grand for a rotating assemble, 2 grand for heads, 2 grand fro a trans...etc...etc...
But I have to admit, thinking about that is kind of making me wonder if I need to do that, as well as some new heads, and I already need a new trans......maybe I should look into an LS swap. Or maybe just leave well enough alone. Like you said, at this point, im looking at some big bucks to move forward. I wouldnt be opposed to some NOS. That seems like the most affordable route. But im a big fan of turbo/turbo's too. I guess I will know more once im able to verify some things. |
