transmission lines
I am thinking about running the transmission line to the cooler through the frame.
My thoughts are enter the frame at closest hole in frame across from the th400 . Cut the metal line just short of the frame with a bend for clearance from headers then place a rubber grommet in the hole .Then with rubber trans-line run it up the frame and exit out the front and go to the trans cooler . To stop the line rubbing a hole use corrugated wire tubing to stop metal on rubber wear on the 2 lines . So with all that will I be able to run the tube past the front suspension . Any bolts or dead-ends in this section of the frame. I really can not see up the frame on the floor I might have to take it to a friends hoist to stop crawling on the floor. OR do I have to run it on top of the frame like factory . |
what was I thinking !!!!
The front springs bright spark .... If you had hard lines and a lot of time you could do it .But I went from the gearbox under the heater box , under the fenders and then out the front . No more lines |
