On to the radio speakers
First off I can fix any telecom system but I know nothing about electonics for radios. Just needing a little advice.
I had the AM radio converted to a AM/FM + RCA connections. The instructions state use 4 ohm speakers. I bought two single speakers to replace the front speaker from our host(RPZ183A). They are rated at 4 ohms. I then bought 2, 6x9 JBL GTO938, they were advertised as 4 ohms, however once I receive them it states they are 2 ohm each. 2+2=4 I guess, thats what on the outside of the box. Anyway, I hooked them up and they sound ok I guess. Will I damage anything with an impedance mismatch. Any advise is appreciated as always.
Bring back my 67 GTO: Shes ALIVE as of 2-19-13 previously owned 78 Firebird 67 Nova 64 Nova |
If you don't crank up the volume full blast they should be ok. Maybe over time they'll crap out but you should be good for now. Tho others will probably have more and better info than me.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
Did you hook them up in series or parallel? Parallel would result in 1 ohm impedance which could damage your output stage.
My money talks to me-it usually says goodbye! |
all 4 are connected to there own 4 ohm channel output.
The 2 ohm speaker will draw twice the current that a 4 ohm speaker would draw. Since your amp is rated for a 4 ohm load, it will likely not be able to provide the current that the 2 ohm speaker would draw at higher volume levels, depending on how much headroom is designed into the amp. If you only operate the system at mid to low volume levels (as GT182 said), where you are not exceeding the current capacity of the amp, all will be fine, but it would be hard to know exactly where this volume level is without measuring the voltage output of the amp. Extended playing at high volumes will likely distort and sound poor, and possibly damage the amp. You would be able to get the most from your system by changing to 4 ohm speakers. Seems like the store should offer you an exchange if the box was labeled incorrectly.
psw |
Acording to JBL's website it should be ok with a 4 Ohm head unit. You probably would need to use a superior brand or an extra amp to be on the safe side.
http://www.jbl.com/estore/jbl/us/pro.../GTO938_JBL_US Quote:
Reef turqoise -66 GTO Firebird Convertible -68 R.I.P. -73 LeMans 350/350 Barnfind |
