Old 03-27-2014, 09:36 AM
67cruiser 67cruiser is offline
Default P4B aluminum elderbrock intake info.
What can anybody tell me about this intake??? Worth anything???
Old 03-27-2014, 09:42 AM
David Jones's Avatar
Which one?
I run a P4B-QJ, which I like.
I haven't heard much to good about a regular P4B
Old 03-27-2014, 09:43 AM
grandville455's Avatar
It works very well!!
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 03-27-2014, 11:02 AM
Formula8's Avatar
Formula8 Formula8 is offline
Darby. I acquired the same P4B that you did and hogged it out to accommodate a Spreadbore. I have not run mine but how did yous work out?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 03-27-2014, 11:51 AM
I never got a chance to run mine , as I sold it and went to the T2/holley deal back then.
Darby
Old 03-27-2014, 12:56 PM
Craig Hendrickson Craig Hendrickson is offline
Pontiac performance Author
The original Edelbrock P4B was patterned after the 1960-61 Pontiac 389SD 1x4 intake with some accomodation for street use (heat crossover, choke, etc.). It was a pretty good manifold for the time if you ran an AFB or Holley carb. If you had 1967+ heads and a QJet, you were better off with the 1967+ Pontiac cast iron intake.
Here's a picture of the 389SD 1x4 intake:
Craig Hendrickson, the "H" in H-O Racing Specialties.
http://www.OriginalHO.com
Old 03-28-2014, 08:39 AM
PONTIAC DUDE's Avatar
Red face
Decent for a stock replacement type manifold if the later 67 & up. Performance wise there are a lot better units out there. If using an HEI check for clearance.
Old 03-28-2014, 08:54 AM
ho428's Avatar
ho428 ho428 is offline
I got decent results with one.
Took a #17 headed 350, changed the 2 barrel intake to the P4B, added a Holley, a set of headers and dual exhaust. Nothing fancy, just a good street tune.
Backed by a 4 speed it was a pretty responsive street engine.
Probably better performing intakes around no doubt, but IMO, a blasted and cleaned P4B looks better than some other intakes.
For a cheap and simple 2 to 4 barrel swap on a 350 or 400 I'd recommend one.
Old 03-28-2014, 09:50 AM
steve25 steve25 is online now
I wish the factory would have kept that long manifold bolt set runner 8 as it does not choke down the port area as in the latter manifolds!
