Anyone know if this is a 76-79 400 timing cover. If not do you know what it is ? Tks.
Yep. It is.
Used with a crank dampener. Not for the low performance engines that just used a hub.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
It came with my car (455) and I can't use it. any idea what it is worth ?
Looks to be in great shape. I'd say $75-$100
www.hobracing.com |
Why not?
Reproductions are out and really nice so good used ones aren't exactly commanding the big bucks anymore. |
I don't see GM any where on this. Could it be a repro. ? I am pretty sure it has been with the car for almost 15YR ?
It is GM, see the part number under the timing mark.
Its ok to giggle and snicker, Dont laugh and point |
Hey Mr lucky one
when you sell something...IN THE CLASSIFIED's..... it on YOU to determine the price. for 155 bucks you can get a really nice. brand new one From Kauffman's. cast aluminum that can be welded on if repaires are required |
Thanks everybody for your help.
I googled it and it probably is a 75-76 GM cover. It appears to be new. Very nice part you have there.
Cant use it? Or don't need it? Or look'n for the correct casting # for year of your car?
Will work on 65-79 blocks if using 69-79 damper and pulleys.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 03-26-2014 at 12:46 PM. |
Tks. again for all your help. I don't have any use for the cover and will post it in the classified. Tks. again for all the help. I hope to have my 65 gto finished soon and and am cleaning out the basement. Tks. again Guys!
