4 Speed Part ID........ Reverse Lights? KIck Down?
I had this with my 4 speed parts and I'm not sure but I think it has something to do with the reverse lights or? Where does it go? I can't find it in any of the catalogs I have. Thanks
73 Trans Am Red/White #'s match 4spd...... sold 69 Firebird 400 conv #'s match AT Blue wht/wht 06 Vette conv Red/Red/Blk |
The part you are showing is a manual transmission clutch (neutral) safety switch. It mounts up under the dash off the stamped steel bracket that holds the clutch & brake pedal. Without taking apart a few pieces on my cars, cant tell which style it is. The safety switch Was designed so you have to start the car with the clutch pedal depressed.
Reverse lights will be activated by the backdrive linkage that connects the lower "leg" on the steering column & the reverse lever on your manual transmission. Often factory back drive linkage is missing on '69+ A-bodys & '69-81 Birds, esp on cars that have had headers installed at one time, or have had engine & trans swaps.
I do not have the reverse linkage as my car was converted over from AT. I guess that is the next thing I need to start searching for. I have read the Camaro and Firebird rods are different which doesn't make sense as the cars are basically the same.
Knowing that this is not for the 73 A body as mine is different then that one shown.
