Old 01-22-2014, 10:11 PM
1966geeto 1966geeto is offline
Default Back up light switch 4 speed harness
Anyone know where the harness for the back up switch on a 4 speed comes into the car?
Old 01-23-2014, 09:43 AM
bob d bob d is offline
search for post by ron tittel on 1/23/13. bob.
The Following User Says Thank You to bob d For This Useful Post:
Old 01-30-2014, 07:47 AM
chrisp chrisp is offline
From dash harness behind cluster , 2 wire plug .
The Following User Says Thank You to chrisp For This Useful Post:
Old 01-30-2014, 08:58 AM
Jeff Hamlin's Avatar
This is one installation that has never been clearly shown in any of the "resto" books so information varies. Never being able to find exact wire layout I went off of what was already in the car when I bought it. My BU wires were run under the carpet/console and down through the shift hole. I didn't like this location so I notched the shift boot retaining ring to keep the wires away from pinch points.
I have also seen the sw wires run up the backside of the bell with a upper retaining clip and the dash wires run out firewall to connect behind the bell. IMO this seems more likely how it should be.
Old 01-30-2014, 09:54 AM
Through the bulk head rubber plug use extra hole that exists , attached to the lower front firewall with clip , to the trans. using 2 metal wire clip holders to the trans.
Old 01-30-2014, 03:04 PM
Peter Serio's Avatar
Default Reverse lamp switch wiring.
Factory routing for Muncie 4 speed transmission 66 GTO. Beyond what this photo shows the wire routes up along the top of the bellhousing. There is a plug-in right near the distributor and then the wire goes along the firewall supported in at least 2 locations by formed steel "J" hooks (sometimes rubber coated). Over towards the drivers side of the car and enters the interior thru a round rubber grommet set right next to the fuseblock. (There is a hole drilled in the firewall, this is approximately 7/8"/1" in diameter.)
Name:	66GTOTRANS_Reverse Lamp Wire Routing.jpg
ID:	351330   Click image for larger version
ID:	351331   Click image for larger version
Peter Serio
Owner, Precision Pontiac
The Following User Says Thank You to Peter Serio For This Useful Post:
Old 01-30-2014, 05:43 PM
Thanks Pete looks like the dark green runs inside the cat to pick up a power source where does the light green pick up the lights ? goes through the ribbon in the car.
Old 01-30-2014, 06:54 PM
Conjoined to the main dash wiring harness there is a plug-in shaped like a capitol letter "V" It will have 2 wires in it. A dark green and a lime green wire. The dark green wire is 12 volts "+" via a fuse whenever you have the key turned on. The lime green wire then feeds one lead inside of the ribbon harness running all the way back to a plug-in behind the rear seat & from there inside your trunk alongside the LR quarter-panel back to the the rear of the car. Then thru holes in the trunk floor on both sides (one hole per side) just forward in the trunk floor inside, just above the ledge for the rear bumper.
Peter Serio
Old 02-01-2014, 05:17 PM
After posting I kept thinking about this and then remembered I once had an old '65 NOS BU light kit and I still have the instructions. This is the complete set of '65 instructions for all models so more info then needed, but should be useful for '66 as well so I thought i would post it all for anyone else interested.
One of these days I get my files in order
Old 02-01-2014, 05:23 PM
Default 1964
Had this on file as well, labeled as '64
Old 05-29-2016, 09:13 AM
tempest1964's Avatar
Jeff, I wonder if you could re-post these installation instruction pictures again. I have a message on your post that says; "photos not found. click for photos". When I click the message it takes me to a link that says photos removed.
Thanks,
Tony
Old 05-29-2016, 09:59 AM
Arrow REVERSE LIGHT INSTALLATION KIT-INSTRUCTIONS
COMPLETE SET/ALL TRANS/MODELS;
1-5
Default REVERSE LIGHT INSTALLATION KIT-INSTRUCTIONS
6-10
11-15
Old 05-29-2016, 10:00 AM
16-20
21. DRILLING TEMP FOR '65 BUMPERS.
Old 05-29-2016, 10:21 AM
Thanks Jeff! much appreciated .
Tony
