Old 01-15-2014, 10:37 PM
Shift'n Gears's Avatar
Shift'n Gears Shift'n Gears is offline
Default 1973 TA - Which Space saver spare Tire?
I have been looking for a space saver spare tire for my 73 TA. I know that there were two brands, one was a Goodyear and the other was BF Goodrich. My all original 79 has the Goodyear, but I can't tell if the application depended on the year or if there was a difference between the Norwood and VN plants. Does anyone have pictures of an original Norwood 73 Space saver spare?
1978 Y84 4sp
1979 T/A 400 4sp Blue/Oyster (special order)
2000 T/A WS6 6sp Black/Black
Old 01-16-2014, 12:05 AM
2manyT/A'S's Avatar
I believe 70-75's were BF Goodrich 14" mounted on a gray painted standard wheel...
Eye Candy......garage band?
Go full screen & turn it UP!
Old 01-16-2014, 04:04 PM
indianhead74's Avatar
indianhead74 indianhead74 is offline
My 73 had a goodrich mounted on a grey steel wheel. Honeycombs with radial whitewalls were on the car
Old 01-16-2014, 05:17 PM
Held for Ransom's Avatar
B.F. Goodrich, on a black painted 'EL' rim.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 01-16-2014, 10:22 PM
2manyT/A'S's Avatar
OK,did some homework...........
Parts book lists: 9793592 69-72 all with 775 x 14 SpaceSaver stamped KC 14 x 6
I pulled one out of a loaded 75 Formula 400 years ago....assuming it was original to that car...guess NOT but I definately lucked out....it's a KC gray wheel & never been down....Perfect for my 70 1/2 T/A.
My parts book is 67-75 and it doesn't give any other Spacesaver codes...need to check the service manual.
Old 01-16-2014, 11:28 PM
highway star's Avatar
highway star highway star is offline
Norwood = Goodyear Van Nuys = BFG, at least for mid to late '70's.
Old 01-17-2014, 01:35 AM
All- Thanks for the input! (And the picture)
Held for ransom- are there markings on the tire? I have seen several with L7CU but I have also seen L9CU. I'm not sure what would be correct for 73.
Highway star- as an FYI, I have no idea what my 73 came with- hence the thread. But my 16,000 mile all original 79 from Van Nuys has the Goodyear. Not sure if that rule changed at some point.
1978 Y84 4sp
Old 01-17-2014, 01:56 AM
2manyT/A'S's Avatar
L9CU is what My 78 has...G70 x 14...........L7CU is 77 and prior F70 x 14,as I recall...
Is your 79 a WS4 or WS6?
Old 01-17-2014, 02:35 AM
I got this info. from John Witzke:
Space Saver Spare tire = Van Nuys BFG L9C4, Norwood Goodyear L9CU
Old 01-17-2014, 04:28 AM
WS6 (W72 / 4sp). Currently has the original tires on it, though I will need to get the new Polysteeels this year as the right front tire slipped a belt last year. Cheap 34 year old tires...LOL
2 Many - What color is your jack and Jack base? I have seen 3 different colors Blue/Black/Grey. I have heard that blue or Black is correct for 73. (My 79 is the lighter blue). Also is the red larger inflator bottle correct for 73 or could you get the smaller blue canister? If I recall the red bottle was used through 77
Highway Star - What year are you referring to? I know that things changed over the years. Exampler L7CU vs L9CU and Grey rim spares changing over to black. John is very knowledgeable about cars, but I am sure that there are differences between early second gens and later second gens.
1978 Y84 4sp
Old 01-17-2014, 06:59 AM
Someone is going to have to prove to me that Goodyear Space Saver tires were on the earlier Firebirds (pre-'77).
Tire is marked F78-14 L7CU. Rim is stamped K-1-3 2 (valve stem) 16 EL.
Old 01-17-2014, 09:41 AM
2manyT/A'S's Avatar
My 73 original jack/base is blue with med. gray tire iron...78 is black & 79-91 is lighter blue with black tire iron...
There was a recall, (late 78?) for ALL 79 WS6 Spacesaver spares.......they discovered AFTER production that the 14" space saver wouldn't clear the brake caliper....so the 14's were exchanged for a 15" with a Goodyear tire.
The red bottle was used till the end of 77 production,as I understand it......the heavier smaller diameter blue bottle was introduced in 78 and WAS re-fillable....red bottle was NOT....so if you went to the dealer for a replacement RED bottle,you got a BLUE one...
John Witski knows a lot about W72 engines and his dad's 77 T/A.......period.... JMO....
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
Old 01-17-2014, 09:44 AM
2manyT/A'S's Avatar
I personally have not documented (original owner) ANY Trans am or Firebird's with Goodyear Spacesavers till the 79 model year........
Old 01-17-2014, 07:27 PM
Well, my '78 Gold SE TA had the Goodyear mini-space.
1973 docs show that the rims may have been grey too. But, Goodrich was the manufacturer.
ID:	349707   Click image for larger version
Old 01-17-2014, 08:57 PM
2manyT/A'S's Avatar
Did you buy the 78 new?
Norwood or VN Build?
Early or late build?
Old 01-18-2014, 02:13 AM
2Many - Thanks for all the info! looks like I have a project before summer now. Curisity has the best of me and I am going to have to check the size of my spare in the 79. I'll let you know what I find.
Held for Ransom - Thanks! where did you find that Tire info?
1978 Y84 4sp
Old 01-18-2014, 12:05 PM
The Spare in my WS6 car is a G78-15
1978 Y84 4sp
Old 01-18-2014, 02:34 PM
2manyT/A'S's Avatar
So it looks like you had the recall..........If you ever get around to it.........post the #'s codes) stamped by the valve stem.
Think I have one somewhere here and I can compare/confirm.
Nocturne Blue???? How about some pics? I think that's my FAVORITE 79 color.
Have you owned it for long?
Old 01-18-2014, 07:43 PM
http://www.forums.maxperformanceinc....d.php?t=560626
I remember that thread.
The docs came from the 1973 assembly manual.
As for the '78, the gold car came from Van Nuys and now you got me thinking on what the tread (manufacturer) was and I don't recall. Tire pamplet was with the car (I was the third owner 5 years after being built (delivered/sold May 13, 1978), low mileage car). I killed it.
My black '78 TA was a 2 owner car from Norwood and it had the Goodyear Custom Mini-Space (T17 12 (valve stem) 16 UA, G78-14). Don't remember the VIN or trim tag info.
Old 01-18-2014, 09:16 PM
2manyT/A'S's Avatar
I knew I could count on you to did that one up.......
Goodyear Custom Mini-spare....is that the "do-nut" style or the inflatable/collapsable style?
