Old 01-14-2014, 04:28 PM
GregL's Avatar
GregL GregL is offline
Default Heater Cores?
Hi Guys,
Has anyone here compared heater cores for a '68 A/C & non-A/C car? I'm replacing mine but the only listings I'm finding are for A/C cars only but they may be the same thing. Your thoughts?
Greg
Old 01-14-2014, 06:23 PM
A Schab A Schab is offline
A/C and non A/C are not the same.
Old 01-14-2014, 06:27 PM
GregL's Avatar
Thanks AS, I do you know if it is a core size difference or a tube difference?
Old 01-14-2014, 07:13 PM
The tubes are completely different. I'm not sure about the core size but I know that it mounts in a completely different way also.
Old 01-14-2014, 07:48 PM
silverbullet07 silverbullet07 is offline
Here you go. https://secure.amesperf.com/qilan/De...A&web_access=Y
Old 01-14-2014, 09:27 PM
GregL's Avatar
Thanks Guys, that covers it!
Old 01-14-2014, 10:11 PM
Old Goat 67's Avatar
Much better.
http://www.oreillyauto.com/site/c/de...rd=heater+core
Old 01-14-2014, 11:10 PM
Be careful with the O' Reilly one. The inlet and outlet pipes are bent really close to the heater core making it hard to get through the fire wall.
Old 01-15-2014, 11:17 PM
Hammered's Avatar
Hammered Hammered is offline
Also beware that the Camaro heater core is often substituted and it's about 1/4" thinner. No big deal if you shim it to fit, but if you don't it clunk around in the box. I actually got the correct part through rockauto.com as our host didn't stock them at the time.
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 01-15-2014, 11:48 PM
GregL's Avatar
Thanks for the input guys. I found one through my local radiator shop. Fit was OK but the 5/8 tube was a little too close to the heater box. A bit of heat to soften the solder and it moved about 3/4 of an inch. Perfect.
Best,
Greg
Old 01-16-2014, 03:03 PM
steveK steveK is offline
and always pressure test before installation!!!
Steve Karew
