Old 12-31-2013, 06:08 PM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
Default More pics of the some upgrades.
New bead locks. Sent my old wheels in, the screw holes for the slick screws were getting worn and stripped, they cut the old flanges off and tig welled new bead locks on.. Everything is cnc and tig even cutting the old wheels, much nicer than some of the others like Mac fab. Should save an the sidewalks too
8.30 @ 165 mph 3,380 LBS
Old 12-31-2013, 06:09 PM
Ray Cox's Avatar
Cnc outer ring
Old 12-31-2013, 06:12 PM
Ray Cox's Avatar
Tire grip
Old 12-31-2013, 06:14 PM
Ray Cox's Avatar
Tig welded on a rotary table
Old 12-31-2013, 06:49 PM
David Holmberg's Avatar
You should try to stay off the sidewalks.
They look nice Ray!
Old 12-31-2013, 07:11 PM
Ray Cox's Avatar
new stainless works Stainless steel header kit is here to start assembling also. They have some nice parts!
Old 12-31-2013, 07:14 PM
Ray Cox's Avatar
Saved at least 10 lbs also
Old 12-31-2013, 07:16 PM
Ray Cox's Avatar
More power?
Old 12-31-2013, 08:08 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
More power?
No
7.940@170.84. 3460#s
Old 01-01-2014, 02:29 AM
66bonne's Avatar
66bonne 66bonne is offline
Ray: If you're coming to Florida this spring for testing be sure to post dates/tracks, I'd like to catch up with you and your car. Maybe we can pry Keefer out of his shop as well.
Jim
Old 01-01-2014, 09:30 AM
Is the Tire Grip a proven technique?
Old 01-01-2014, 10:27 AM
Ray Cox's Avatar
In the drag racing industry, yes. But here on py nothing is proven and anything will be debated denied and argued forever.
The Following User Says Thank You to Ray Cox For This Useful Post:
Old 01-01-2014, 12:08 PM
Some O2 bungs going in the header in the picture?
Old 01-01-2014, 12:21 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Debate, discussion, counter view points and opinions...yes...even when spirited and what may seem or be quasi disrespectful is what helps invoke change, thought, experimentation and progress. Without it , here or in the real world, we would be doomed to stagnation and failure.
You of all people should understand the lesson of the lemmings.
The Following User Says Thank You to GTO Dan For This Useful Post:
Old 01-01-2014, 03:11 PM
warriors revenge warriors revenge is offline
Send a message via Yahoo to warriors revenge
^^^^^^ LMFAO!!!! what wheels are those Ray????
Old 01-01-2014, 07:11 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Ray who did the bead locks?
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 01-01-2014, 07:19 PM
Thanks for the affirmative.
Old 01-01-2014, 08:11 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Indy Cartel. Joey B does good work bro.
The Following User Says Thank You to Aaron Quinton For This Useful Post:
Old 01-01-2014, 08:12 PM
Ray, the bead locks and pipes look awesome. I'm guessing when you get the heads in place you'll be running 1150 hp NA or so. Add the juice and better numbers are a tune away. Keep rockin man! Well done.
Old 01-01-2014, 10:41 PM
LiL Jack's Avatar
Are you high?
