Old 12-06-2013, 05:17 PM
wmurrell wmurrell is offline
Default '65 Brake Drum Question
Was it possible to order aluminum drums with the metallic brake option in 1965? I would have thought that the metallic brakes would be too aggressive for the aluminum. Thanks!
Bill
Old 12-06-2013, 05:40 PM
Ken K Ken K is offline
Only the outside is aluminum, they are steel lined. You can have them resurfaced just like a normal brake drum.
Old 12-06-2013, 06:36 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default No
You could order one "or" the other (metallic linings or aluminum drums) but not together.
The metallic brakes were designed to work better with high heat.
The aluminum drums were designed to do the opposite.
Name:	65-66 GTO Aluminum Front Drums (5).jpg
ID:	345697   Click image for larger version
Name:	65-66 GTO Aluminum Front Drums (9).jpg
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 12-07-2013, 01:03 PM
Thanks for the info & photos 60sstuff!
If you ordered a 3.90 rear, it forced the metallic brake option. Since the metallic brake option cannot be combined with the aluminum drums, it would dictate that all the cars with aluminum drums would have to be non-3.90 rear cars.
I have copies of the billing history cards for ~70 ’65 GTO convertibles and checked to see if this held true. I found 7 cars with factory aluminum drums. Six had a 3.55 rear and the seventh had a 3.23. Learn something everyday!
Old 12-07-2013, 03:25 PM
Talking
The big difference is you can sell the aluminum front brake drums for big bucks. They were selling for crazy money on ebay. Metallic pads or aluminum drums are not in the same league as disc brakes. It's the haves and have nots.
Old 12-08-2013, 10:34 AM
John V. John V. is offline
The metallic brake option also came with specific brake drums.
I do not know how they differed from the drums used with the standard brakes, but specific drum p/ns were specified with the metallic brake option.
So it wasn't just the shoes that changed.
IIRC, you could order the metallic brake drum option with any ratio from 3.08 and up '65, 3.23 and up in '64. And as Bill points out, if you specified the 3.90 ratio, you were required to order the metallic brake option. There was a factory 3.90 axle with standard brakes but it was not used for the GTO (I think it was only used for a 6 cyl application).
The Following User Says Thank You to John V. For This Useful Post:
