There are ten 5|16 diameter plastic washer/sleave combination pieces that look like seals of some sort that came in the felpro engine gasket set we have. We are assembling a 1972 455. I didn't see were they should go. Are they neededto seal the ten water pump bolts? I couldn't see as to how they would be used in this motor. Thanks, chad
If they are blue, they are for holding the oil pan gasket to the oil pan. I don't use them because I glue the gasket to the block.
i think I've seen orange ones that center the intake gaskets
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
![]() Quote:
Yes, but there are only 4 of those.
