Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
*** THE BIG BRACE is here *** |
That was a fun build. Can you imagine the look on some doctors face when he gets blown away in his Ferrari on I-65 by a station wagon? Lol
Lol exactly !! Nice simple build .
A good video for showing how to install billet caps and the BOP seal.
Is there a turbo "pattern build" for all components/more specifics for replicating a similar project available?
What power did that make in the car?
It kept blowing the charge pipe off on the dyno. |
Here's a nice video of how they did the exhaust piping etc...
http://www.powerblocktv.com/episodes...le-motor-build
![]() Quote:
What a great build and feature. Your family is 'living the Pontiac life" and doing so well. congrats. One question though.. While watching the video of the build, I noticed you did not drill the block deck for the extra cooling hole ( above the center head bolt hole on the lower row). Also noticed your gaskets do not have the hole either. However, the hole did appear to be in the heads. Based on this, do you feel this mod is not needed? I have used it for a few decades now and really think it helps cooling in that center area where the 2 exh valves are and helping to extend head gasket life. Comments? Thank you again for all you and your family do and have done for our Pontiacs!
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
Steve... this may be of interest... I was drilling a scrap 6x head just below valve cover rail and between the outboard center bolt.... there is a "vein" cast on the centerbolt boss that extends out into the water cavity almost to where the "cooling mod" hole is. I would guess its there to help pull heat away? CV1 heads have a similar feature cast in which IS intended for that purpose.
I drilled along the entire rail looking to see if I could plumb reverse cool similar to the water tubes in the 55-59 heads... seems I can get similar effect that way... 9 holes @ 3/8 id is about same total area as hose id of the early timing cover... and can get close to each valve plus add the extra feed in front of the centerbolt... would be like plumbing a fuel injector rail. Water can exit out the ends on manifold side of head. Very little water actually flows thru the early blocks. http://www.pontiacsafari.com/EngineCooling/index.htm for anyone wanting to see exactly how the 55-59's were reverse cooled and the changes made for "conventional" cooling in 1960. |
![]() Quote:
Hey Bruce, could you get a few pictures of where you drilled? I have been thinking of trying what you might be doing. ![]()
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
I did the "421 cooling mod" to my combo few years back when I had everything apart for inspection.. Also tapped the 2 front holes in the deck on each bank if I remember correctly.... Every bit helps when you have a block that's almost full of hard block. Plus the cooling flow at the center of each head can't be bad.
Kris.
Rodney, Please advise your machinists to wear eye protection when running equipment. I have been around a machine shop all my life and have seen some terrible things happen in a fraction of a second. PLEASE make it a shop rule to were eye protection. As for the video, excellent, very well done. Your dad should be very proud of the way you continue to conduct business, present yourself and the family name. We are fortunate to have you and your team designing and building Pontiac power. Thank you for that !
All the best to you and your family. Tim john--- |
I'll see if I can get enough light and get a few pics sometime soon.
![]() Quote:
Study the link above I posted. Plenty to learn there, including changes made when they went to conventional cool in 1960... take note of all deck drillings... early motors had the "421 mod" before the 421 came to be! Note difference in upper deck holes below crossover... The blocked ones are there to prevent water from the pump shortcutting out the crossover on conventional system. Early rev flow they are open. If you open them on conventional cool system and your temp gauge is in crossover you are likely to read lower temps yet block/head coolant further back likely much hotter due to the short cutting to the crossover... Be careful what you change. |
Loving the info in this thread and a great show it was about time they did a Pontiac motor with real potential
