#61
No, I think you have a valid point. Very possible that it could affect the cooling to the rear of the '59 block if used for conventional cooling. I would have to take a look at my '73 block to see how the later blocks were the drilled. I still some the heads on it and will have to remove them for a pic. I wonder if adding a rear water entrance in the block would help even out the coolant's effect on the '59 block?
Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
#62
Would be very easy to just drill, tap & plug the front holes on the 59 block so the coolant holes match the newer blocks.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
#63
Good point Keith. That would allow you to try it both ways. You could always remove the plugs if it makes no difference or an adverse difference. Mark L
#64
Easy,,deck is pretty thick in that area. Use allen head shallow brass pipe plugs & tap the holes to let the plugs set just below deck height. Can remove & reinstall as needed. Or,,,plug all of them & go dry deck. So many possabilities!
#65
Also, you could modify the water ports in the heads rather than the block.
#66
You could,,,but would rather do the block. Whats a block worth vrs. the value of a set of virgin unmolested SD 306 heads??
#67
block is a good boat anchor to most pontiac guys,the heads are another story!Tom
#68
Don't short sell the block, it is desirable to some of us. The 59 block is a bolt-in replacement to 1955-58 blocks making it a desirable/easy 389 cc engine upgrade without changing the appearance of the engine. To some old timers the block would be more desirable than the heads. But I'm sure the 306 heads are worth more.
#69
So, just what are a set of unmolested date code matching 540306 heads worth these days?
#71
Don, I think you mean 535461 heads -- with the larger intake valves. That surely was one cool, I mean hot, '59!
#72
Start at around $1500 & go up from there!
#73
heads $$$$
At those prices, I guess it would be worth my making a 100 mile trip to see if that pair of them I saw collecting dust under a bench in a garage shop a few years ago are still there!
Didn't the 540306 "evolve" in that the originals had pressed in studs and latter ones had pinned studs? |
#74
as far as I know all 306s had pressed in and pinned studs.Tom
#75
I have now placed the heads in the classified section for sale. Mark L
#76
Sale is pending payment. They be heading to Texas. Mark L
