Old 09-04-2012, 12:04 PM
El-bandit El-bandit is offline
Default 64 GTO Tri Power
I have a 64 GTO Tri-Power setup for sale. It has the correct center carb. The end carbs both look to be rear carbs so one would have to be drilled and tapped for the vacuum fiting. It has the correct water neck and the stove pipe that goes into the manifold. Included is the piece the heater hose attaches to.
All carbs will need to be rebuilt the carb on the front has a broken arm on the carb top (see picture). Center carb will need the guts for the choke. All carbs operate freely and are not stuck. Don.t know if these are numbers correct; but, they will function correctly.
lI would have to verify: but, I believe the date code is third week of May.
This setup would fit 61 to 64 but the manifold is considered correct for 64 and is a one year item
Asking $700.00 + shipping.
ID:	296530   Click image for larger version
ID:	296531   Click image for larger version
ID:	296532   Click image for larger version
Old 09-04-2012, 12:13 PM
Default 64 GTO Tri-Power
More pics
ID:	296534   Click image for larger version
ID:	296535   Click image for larger version
ID:	296536   Click image for larger version
Old 09-04-2012, 12:33 PM
Default Wire spinner hub caps
I also have some 65 66 wire caps as well as three of the un-vented 64 wire caps.
. 65 66 vary in condition with dings small dents, and some curb reah. The 64's have some minor damage with one being reaol nice with very little damage ( won't show in photos).
I will post the 65 66 photos seperate from the 64.
The 65 66 are $25.00 each and the 64's are $75.00 each
ID:	296540   Click image for larger version
ID:	296541   Click image for larger version
ID:	296542   Click image for larger version
Old 09-04-2012, 12:35 PM
Default 64 GTO Parts
more 65 66 caps
ID:	296544   Click image for larger version
ID:	296545   Click image for larger version
Old 09-04-2012, 12:38 PM
Default 64 caps
the 64 caps
ID:	296547   Click image for larger version
ID:	296548   Click image for larger version
Old 09-04-2012, 02:06 PM
bigpop bigpop is offline
El-Bandit,
Please further describe the 65-66 wheels.
Spinners (pot metal)- 1) pitting situation.any cracks,deep scratches,rub marks.etc.
Spokes- S/S IIRC, straight? any physical damage noticable? all there?
Cover body- Same as above #1 , especially the curb rash.
Thanks Larry B.
Mr. President, you can't say Dallas doesn't love you "
Old 09-04-2012, 04:21 PM
El-Bandit,
Looking at your carbs the end carbs both appear to be FRONT CARBS not Rear Carbs
as listed in your post. That is not a show stopper for the potential buyer as Tim Benko has new bases and new tops for the carbs with the correct levers/etc.
A good buy for someone, IMO.
Tom Vaught
Old 09-06-2012, 09:20 AM
Default bump
Reasonable offer????
Old 09-07-2012, 11:46 PM
Default going to ebay
will be posting to bay if no interest
Old 09-12-2012, 12:15 AM
Default bump
bump
Old 09-12-2012, 01:01 PM
tom s tom s is offline
PM sent
Old 09-13-2012, 12:24 AM
Default reply
PM's answered
Old 09-16-2012, 10:37 PM
Default bump
bump
Old 09-23-2012, 01:56 PM
going to ebay
Old 09-25-2012, 12:09 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Price for 4 of the 66 covers to 37335
Thanks!!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
