Front Steer Sub Frame Transplant
Hello All
I am going to build up a "68" Firebird Sprint 6 Clone and it may house the BMFH too someday. I didn't think there would be any difference 67-69, but maybe. I am also going to retro-fit a Nova Front Steer sub frame to get more clearance for the Oil Pan, because the BMFH has a Dry Sump Oiling System and needs more room under the engine for pan clearance. If you are wondering what is a BMFH, here is a link to look at. http://www.geocities.ws/ohcjhatch/index.htm I have heard that installing a Front Steer Sub Frame is somewhat difficult because you have to Re-Fabricate the front frame ears, and convert them so that the Firebird bumper can be mounted correctly. I don't want to cut off the Original Firebird Sub-Frame ears for the parts, and Destroy an Original Firebird Sub-Frame. Speaking of Sub-Frames, does anyone have a Severely Damaged 67-69 Firebird or Camaro Sub-Frame that still has good front frame ears that they wouldn't mind cutting off the frame for me, and I would purchase them from you, just forward of the Suspension Main Cross Member, is the parts of the frame that I need, including the small cross member to keep everything in alignment. Some light damage could be OK, if easily repairable. I can fabricate the new frame ears from Scratch if I have to, since I am also a Journeyman Level Welder and have been fabricating things for about 50 years, my Dad had a welding shop when I was growing up and taught me how to weld. Has anyone else done a Front Steer Frame transplant? I would greatly appreciate any guidance from others that might have done this. Take Care All, and thanks for your attention Dusty |
i have a stub that has nice front horns, but the rear of it it toast..like rusted in half...
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
forgot to add that you may want to consider a rack and pinion.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
S & W makes a real nice rack and pinion bracket kit.
