[QUOTE=Singleton;4579024]I have a SD421 "990" crank that has the fully grooved mains. This was apparently done on 11/19/62, the date scribed on the first counterweight. It was also stroked to 4.5" at this time, which I assume was not common for the time period. Inscribed next to the date is "Lees Custom Motors". I haven't been able to find any info on this machine shop.
Tony Have you weighed the 421 crank Tony? Curious, guessing 80+ lbs.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Didnt we have engines leave the factory with full groove main bearings .. Same same as a groove in the crank. They seemed to do well..
At this build level its all a moot point... either full groove 3/4 groove or half groove main bearings will work great..
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
I believe it's 78lbs, but that was on a bathroom scale, so not very accurate. It has obviously been extensively welded/balanced due to the added 1/2 stroke and the 4.180 M/T pistons that came with all the parts.
I would have never thought a SD 494 cid pontiac could have been built back in 1962, but obviously someone did it. How much weight was removed from your crank?
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
my cheater-matchrace 421 engine had a 1/2 in stroker crank in it.That was in late 63 early 64.Tom
Did you know of anyone else running a 4.5 Sd motor back then?
My unit weighs 64 lbs now.
we did not run it much,CR was stupid high for back then.Tom
Guess that explains why my 127 heads had the 68cc chambers opened up to 76cc's; to keep the compression around 12.5 or so...
Well I measured the crank groove. Not as deep as I thought or quite as wide. It's .080" wide by .015" deep. The crank is already .010 under another .010 off the journal reduces the groove depth to .010" and will reduce the width some.
I'm not going to worry much about it. Just going to use a regular upper groove only set and chamfer the bearing oil hole toward the sides a bit. Took some pics then put it on my scale. Nice... 65 lbs. Think more could come off it. |
That's good.
Or your could have an 80 mil grove cut deep into the LOWERs, just for "theoretically positive" oil pressure at all crank positions.. |
Not me! The little bit thats there now might add just a touch more oil to the rods. At most mod the bearing a bit to get oil halfway between groove and outer edge and I should be fine.
