63 Lemans Brakes
Anybody got an idea on how to go about getting brakes for these things? I feel like I'm beating my head against a wall. I'm wanting to do a complete brake job (drums,shoes,wheel cylinders, hardware etc.) ANY HELP would be greatly appreciated!!
http://www.amesperf.com/index.html |
Just went to the Ames web site and they DO NOT cary any brake components for the '61-'63 Tempest/Lemans
Hey Guy!!! Welcome to the PY boards!!!! Its there, go back to Ames, click on parts search, then select 61-63 catalog, then select 63 year then select trans,clutch,brake section then select subsection for the brake part needed. They have just about everything except for drums. I belive drums are still available from www.kanter.com Also while on the Ames site, request a hard copy of their new 61-63 Tempest catalog!!
When you have time, post up some pictures of your car!!!
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
I would replace all of the steel lines while your at it!!!
Peter Serio Owner, Precision Pontiac |
Depending on their condition. All of mine are factory stock with no rust. Of course, everything should be inspected for any condition issues.
FWIW, Last 63' we did eveything came from Kanter Auto.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks Keith!! Since Ames is the only one who took the time and money to put together a catalog for the 61-3 Tempest, I prefer to use them. They continue to work with the Little Indians to build on this catalog to make it a one stop shop for all your early Tempest needs.
Gary |
Some 63's (V-8's?) had "finned" front drums. If you are going to keep it "stock", these finned drums would be a slight improvement over regular drums. If you are not keeping it stock, go ahead and install front disc brakes using the "Scarebird" brackets. His system uses off-the-shelf late-model-car components available at most auto parts stores.
RE: 1963 Tempest rear wheel cylinders. Ames only lists rebuild kits. Kanter shows one but they are unique left & right, uh, right? anybody know if they fit? do they have a universal fit or something?
I think the fronts are unique left or right but I might be wrong.(I might be thinking of the outer tie rod ends!) I suggest that you take your old rears (and fronts) and send them to White Post and get them sleeved with bronze liners. They'll never rust!
I've seen ads in some rod books for another outfit that does the bronze liner deal for much less cost than White Post but I can't remember the name. |
Hmm I like the sound of that... anybody have info?
As I recall, I was looking into this bronze sleeving about 6 months ago and White Post was asking about $80 each and the other guy was asking about $50 each. I might have seen the guy's ad in Hemmings. (White Post is in there too.)
I think this is the number for white post. 540-837-1140
I'm leaning toward stainless sleeves for wheel cylinders these days. |
What are the pros & cons... stainless/bronze
I doubt that it makes a "rats asp" of a difference!
Call Mark and ask him why he sleeves in SS.
413-789-8665 800 528 5235 |
Found a place called apple hydraulics they have two prices 50/sleeve only 85/sleeve and rebuild. but also turned up a dissatisfied customer rant
There is a l+r rear wheel cylinder and i think the fronts are universle.
I have the fronts out of mine I'll check tonight to make sure. GT. |
For the rears, there is a RH and a LH side, they are different.
Has to do with the casting and the angle that the lines enter from.
