Old 01-03-2012, 09:37 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Default Replacing hood springs
How difficult is it to replace the hood springs? My 72 hood just about needs a stick to keep it open.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 01-03-2012, 10:10 PM
GStage1's Avatar
GStage1 GStage1 is offline
Use a large screwdriver and you can easily slip them off the mounts....doesn't take much effort.....while you are working on the hinges....just for excessive play in the rivets.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 01-03-2012, 10:14 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
I dont doubt it these 72 hoods are not small or light
Old 01-04-2012, 08:04 AM
48pontiac 48pontiac is offline
I made spring removal tool took two pieces of 1" steel bolted together loosely in the middle and notched one end then put a turn buckle on the other it easy to use and safe
Old 01-04-2012, 08:27 AM
hakansan's Avatar
hakansan hakansan is offline
Check this video:
http://www.youtube.com/watch?v=ay7vFc7xC6c
`70 GTO, 370 hp, 3:90, TH400.
Old 01-04-2012, 09:50 AM
67drake's Avatar
67drake 67drake is offline
Originally Posted by hakansan View Post
Then you repaint the scratches on the fender.
Take it easy on that paint job!
Anyway I've seen it done with simply sticking pencils or wooden dowels between the spring coils while the spring is expanded. That way no need to build a tool (and probably less paint scratches).
13.95 @ 102.1 on street tires @ 4055lbs.
Old 01-04-2012, 01:09 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
on my 69 GTO.
put on the fender cover,blanket or something like it behind and tucked near the back of the hood.
a lenght of rope, like the size you would use for cloths line[dia.wise],wrap the spring with a bath towel.
loop the rope onto the hook part of the spring towards the front of the car,pull on the rope and guide the hook past the hinge,spring is off. Reverse to install spring.
It's easy and no paint scratches.
color me gone
Old 01-04-2012, 04:38 PM
Loffen's Avatar
Loffen Loffen is offline
Uhh would not like to have my fingers near that spring when the tool slips...
I just use a J hook with a T handle and pull it of when the hood is open, never had any problems.
Old 01-04-2012, 05:57 PM
Hakansasn that is a much better tool than mine I will make one for my self
Old 01-04-2012, 10:23 PM
So, definately don't take the hinges off to replace the springs then?
1964 GTO Auto
Old 02-05-2012, 12:21 AM
raidex1's Avatar
raidex1 raidex1 is offline
Default Hood springs
I bought and installed the correct hood hinges and springs from Ames Performance and I still need to use a stick to hold my hood up. Beware.
Old 02-05-2012, 08:27 PM
SRR's Avatar
SRR SRR is offline
Old fan belt. Works every time, no paint damage.
― Calvin Coolidge
Old 02-09-2012, 09:38 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
I agree......the fan belt method works best.....much easier to get
a good grip than a rope. Also, I've installed several pairs of repro hood
hinges and they held the hood up just fine, no stick required!
Old 02-25-2012, 02:40 PM
Goat & Chicken Farmer's Avatar
Goat & Chicken Farmer Goat & Chicken Farmer is offline
I have the same problem with the Ames springs and hinges.
"Lucy" 1971 GTO (dad's) A true clean one owner. all orig. #'s match, 400, 4 sp, P/S, A/C, Lucy Blue
"Buffy" 1969 Firebird vert (mine) Not a clean one owner. Born Carousel Red, 350 2bbl, A/T, P/S, P/B, A/C. Now, Primer gray. Will have a 400, 5 sp, P/S, P/B, A/C, Black with carousel red pin stripes.
Old 05-15-2012, 10:42 PM
Amigo-2k's Avatar
Amigo-2k Amigo-2k is offline
3x for me... I recently installed new springs and hinges from Ames, and when I sit down in the drivers seat the hood comes crashing down. I'm going to stick my original springs back on the new hinges.
1970 GTO
Car Show Tips
Old 07-17-2012, 08:49 AM
pggto's Avatar
pggto pggto is offline
I just put new springs on my 70 GTO, I've had the springs for a long time, still in the GM packages. But I had a little different way to change them, it was pretty easy to do.
I just cut up some plastic strips .100 thick and inserted them in the spring gaps when the hinge was down (hood was off) and lifted the hinge and the spring almost fell off. To remove the plastic shims I just used a floor jack with a hole drilled in a piece of steel to expand the spring. Just reversed the process with the new spring, work pretty good.
ID:	291435   Click image for larger version
ID:	291436   Click image for larger version
ID:	291437   Click image for larger version
