Trunk floor replacement(again)
I came across this and was wondering if it would fit a 70 Lemans?
http://www.ebay.com/itm/70-1970-Chev...item334ed069e0 My biggest concern is the rear section since mine is pretty much all gone. I somehow doubt it will work since the place only lists it for a 70 Chevelle, but who knows? Thanks, Russ |
It will fit since 68 to 72 a body gm is the same, but you will have to remove one of your rear quarters to get it in
But I can sell you a correct one from Goodmark if you like
Unfortunately the 68-72 A bodies are not all the same in this area. That would be too easy. All the full trunk floor panels I have come across require serious cutting in the area that I am looking to replace.
Things like the 3 or 7 piece kits or the smaller (around $119 us) panels are universal, but the area that goes up at the very rear to the seam is different on different cars of those years. I just found this one from Goodmark. As it says it must be trimmed at the tail for Abodies other than a 70 Chevelle. Oh, well. http://www.goodmarkindustries.com/pr...d=4033-725-70S Oh, and I have the body off the frame. No problem with replacing the floor. Thanks, Russ Last edited by russosborne; 12-27-2011 at 10:42 PM. |
