Old 03-03-2011, 08:19 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Default Supporting the front end on a 2nd gen
Where is the best and safest area to place jack stands to support the front end? On the subframe near the radiator support or on the subframe behind the front wheels?
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
Old 03-03-2011, 10:51 PM
Tunas73TA's Avatar
Tunas73TA Tunas73TA is offline
It depends on what you are planning on doing once its in the air.
As long as the stands are under the subframe, either in front or behind the front wheels, you'll be fine. Obviously, the further back along the car you place them, the higher the front end will be up in the air.
weeeee..
chuck...
1973 455 TA (07A)
Old 03-04-2011, 03:26 AM
Currently, I need to get under the car behind the engine to remove the clutch housing cover and try to check the "endplay" on the crank (checking to see if the thrust bearing is shot).
In this situation it might be best to place the jack stands up front where they will not be in my way. But in general, I just wanted to get a feel for where others put their jack stands. Obviously, I don't want to hurt myself or the car.
Old 03-04-2011, 10:34 AM
bobzdar bobzdar is offline
If I'm working on the trans, I usually put them under the control arms where the spring pocket is. That way they're out of the way of any work you're doing and you can still get the car pretty high up in the air.
Old 03-04-2011, 12:07 PM
T A 70's Avatar
T A 70 T A 70 is offline
Me too..
Old 03-07-2011, 05:09 AM
Formulabruce's Avatar
X3 !!!
Old 03-13-2011, 02:45 AM
aronhk_md aronhk_md is offline
weeeee..
Wow....I hope you have that thing supported in some other way that I cant see. That angle on the top of those jackstands...scary. I'd be afraid the hood would slide off too...lol. Be careful please. I'd prefer to keep the market on car related accidents to myself...lol. The whole time I was compressing the springs to remove the A-arms recently I kept counting my fingers and keeping my face behind the A-arm. LOL
Old 03-13-2011, 10:43 AM
Tunas73TA's Avatar
You are 100% correct!
The vehicle made it back safely to earth..I just put that up as an extreme example:
The front was well supported as the top of the jack stands were contacting the frame where one of the body mount was,
so they were kind of in notch area.
The possibility of the hood rolling off my swim tubes didnt occur to me untill after I took this pic,
but it held ok as the tubes had been a bit squished flat and kinda sticky.
chuck...
1973 455 TA (07A)
Old 03-14-2011, 09:03 AM
The best place to support the front of a 2nd gen is just behind the cowl body mounts on the subframe.
To check end play, you can grab or gentle pry the balancer to check fore & aft movement.
Old 03-18-2011, 10:52 PM
Silverbird Silverbird is offline
Here is I supported mine to clean the bottom, subframe removed.
Jack stands at the front cowl / body seam , rear on the tires on top of 6x6 pt beams.
I cleaned the backhalf first, rear end, tank removed then reassembled & did the front.
Just high enough to get under it on a creeper
Very Stable especially with it sitting on the tires.
ID:	238487   Click image for larger version
1972 T/A 455 TH400 (sold)
Formerly..... Dreambird72
Old 03-18-2011, 10:59 PM
I cant believe the hood didn't roll off on the round foam ....WOW ... ballsy !
Old 03-18-2011, 11:39 PM
Tunas73TA's Avatar
Yea...
I've had those jack stands under more spots on this car than a OBGYN's exam chair foot rest!
#1 rule of jack stands is to use them..on a solid surface, with common sense
chuck...
1973 455 TA (07A)
Old 03-19-2011, 08:48 AM
Silverbird - That's your car in your avatar? Any pics? I've been toying with the idea of painting mine silver....
