How many do you think they have, a couple hundred?
I would have to think quite a few people have purchased them already and the site is still showing while supplies last. Well I have mine coming, should be here monday or tuesday this week!!!!!!!!!!!!!!!! Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
Thanks John
You got one Mark?...very cool!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
I set my intake on my spare/old 406 with 96 heads and it aligned up perfectly with the mounting bolts som mine atleast won't need to be milled. I hear that's a common problem with the Victors
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
I will check mine on a set of heads when they come in and report out on the fit of them too.
Tom Vaught
Jeff,
Yes I did!, I couldn't pass on that deal, and I would like to use it in place of the torker II, maybe it will work a little better with the dominator. Later down the road if I get a job with steady income, or my business miraculously takes within the next couple of years, I might look at fuel injection. Mark
The nagging question is what is everyone going to do when the supply is gone???? Is Edelbrock making something new ? - maybe to fit the new gerneration of heads ? Inquiring minds want to know
Chances are they arent discontinuing. My thought is their computer raised a red flag that they have too many sitting on the shelf taking up room in a warehouse on a slow moving item. Might as well blow them out at cost and have the investment back in the kitty to use for something else. Then instead of having 100 on the shelf they'll keep 20. Just a guess on my part though. I really doubt there is something new on the horizon when the old ones work pretty well and probably will work well with the new heads.
My best guess is they overproduced, did a chevy run on them.
Turned out to be a PLUS for us Pontiac guys!!!!!!!!!!!!!!!!!
Mark
Well both of my intakes came today. Excellent bolt alignment (side to side). Might need to cut the cross-over off to get the runner alignment perfect vs the cross-over position but that is no big deal. Injector Boss bores look really nice. I will probably upgrade to a 1/4" fastener between the Injector Boss bores vs the stock size.
Plenum dividers and the rest of the intake looks like a 5 star deal. Well worth the money and put them on the shelf til I am ready for them. Tom Vaught
I got notice that mine was shipped today....lol. You got yours quickly Tom...you and Mark must live next door to Edelbrock's warehouse...lol. Mine is going on the shelf for a while too. Too many other things going on, so it'll probably be a project for next winter.
Got mine about an hour ago.
Looks purrty. Now need to figure how to plug the injector holes so I can use the intake. Mark
I checked my intake for the Injector size. I was afraid that the manifold might take the Peanut Injectors. It takes the normal High Performance Bosch Injectors just fine.
Tom Vaught
Maybe something like this can be adapted to plug the injector bores. http://www.auto-nomics.com/cgi-bin/s...part=12165-005
Don't think so. WOW $40 for 4, you would need 8!
I will check tomorrow and see if I can get a 160 plugs made with the proper o-ring. Thinking $20.00 for a set of 8, plus shipping. Any interest? Tom Vaught
Just put fogger nozzles in there
Would small freeze plugs work? I've used them for EGR block-offs. |
I'll take a set, Tom. What'll hold 'em in there?
#38
Tom I was thinking the same thing. I ordered a intake too and work at a machine shop. If you come up with something let us know. I wonder how many of these intakes sold thanks to the heads up here on PY?
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
#39
Lets see.....8 injectors.....10 fingers....
Sorry, warped sense of humor I would think the o-rings would hold them in tight, but maybe I'm wrong? If these plugs have a flat top could take some bar stock and drill holes for where the rail stands are supposed to go. I know of approximately 20 that have been purchased in the last few days. |
#40
I'm in for a set.
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/248@.050 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker. |
