I know the difference between the two is the length of the crank "shaft". What is the length of a deluxe regulator?
I'm new to the PY Forums. Did you ever get an answer? If not, I can check my '67 when I get home tonight and let you know.
I'm new also. Any measurement of either a standard but especially a deluxe shaft would be extrememly helpful!!! Thanks.
The length of the shaft on the OER deluxe window regulator is 1 inch. My '67 has the deluxe interior so I don't have any idea about the Standard shaft length. Sorry.
After sending the reply I remembered something about a difference between RH and LH regulators. The LH is the 1 inch shaft. The RH OER deluxe regulator shaft is 1-3/16 inches.
FYI - The rear quarter regulators are the same for STD and Deluxe interiors. |
did you find measurement?
If not Ive got some loose ones .....somewhere.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Gen1Bird supplied the deluxe measurements. I'd like to get the standard measurements also as I have several regulators that came in a box (as did a lot of my car) that I'd like to be able to positively identify as a standard or deluxe.
The std ones have 2 grooves on the shaft. Deluxe have 4 grooves.
The Following User Says Thank You to Kurt S For This Useful Post: | ||
