1969 Trans Am Heads
I recently purchased a 69 Trans am project
The car was in peices, but mostly complete. Original engine is there and complete including some pulleys and brackets, but there are three sets of heads. Two sets of 48 heads and one set of 62 heads. One of the 48 sets and the 62 set are both dated to match the engine, but I am unsure which set would have come on the car originally The car is an Automatic RAIII car without AC Thanks in advance for any help
Too Many Trans Ams |
Personally...
only saw "62" heads on a California build and I believe it was an air car. Not sure, though.
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
I had a California built #'s matching automatic A/C car a few years back. It also had 62's on it. Not sure where that car ended up. It was loaded with almost every option and NO radio!
The Following User Says Thank You to Uncle Judge For This Useful Post: | ||
From DeMauro's Firebird decoding guide. 62s list as RA 3 Auto with AC. 48s as RA 3 with manual. 16s for RA3 Auto without AC--which is what you want and don't have ...
The correct heads for a 1969 TA -w- automatic transmission are #62s. Pontiac stopped making #16 heads in 68 thus you won't find any dated 69.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
The Following User Says Thank You to RAJ7395 For This Useful Post: | ||
69 TA
had a 69 auto non a/c TA back in 93, it had #62 heads... car was completely original, but rusted out..
You guys are great
Any Engine compartment pics out there? It would be cool for reference later Thanks
Here is a couple of pics of a local guy's RA 3 4-speed TA.
BTW he has 48 heads. |
The Following User Says Thank You to boater bill For This Useful Post: | ||
Search for 'fbirdinconcord' s thread on his very original VN TA. Tons of great pics & info there.
The Following User Says Thank You to Transamric For This Useful Post: | ||
Sorry...
I totally disagree with the implication of ANY '69 RA engine leaving the factory with "16"s in place. I did a nationwide study years ago therough "The Legend" with no documented case even alleged...let alone proven. JMHO.Ron BTW...I'd go wit hthe "48"s to be safe...or prepare to argue with the "experts" from here on out. Ask them to document just one car for you while you are at it. Good luck.
all of the automatic ra3 69 t/a's that i have personally owned have had 62 castings on them.
The Following User Says Thank You to muscle_collector For This Useful Post: | ||
I think I will send both sets, the 62 and 48 that are dated correctly to the machine shop
I will put the 62 heads on the car, but wrap the 48 up and stick them on the shelf. That way I will have both sets with correct dates and I can swap them if needed
