68 Endura bumper
The bumper is nice, but twisted on the left side. It looks like it was hit to the left of the nose, lower area. Can these bumpers be straightened?
I remember the bumper on my 68 was very heavy. I would say it could be repaired but it wont be a easy task.
Yes they can be straightened - a good body/frame man can do it.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
If you lie awake at night enough, you can think of a lot of ways to manipulate one.
First thing you have to do is realize that you can't hardly hurt it trying to straighten it with anything you might have around the shop. Come-along, chains, tree stump, fence post, etc.
Greg Reid Palmetto, Georgia |
I love that picture!
You can be real adventurous when you have nothing to loose!
Greg now thats thinking outside the box!!! |
The time will come when you realize that the worst you can do is F it up...and since it's already F'd up, why worry? LOL
Post #1 exactly described (s) my 68 Endura: Bent Lower Bar.
After many sleepless bar-bend configurations, I managed to degrade the Endura surface finish for a minor lower bar improvement. Good enough to fit into alignment. This allows me ample time to find & paint a sweet Starlight Black endura someday. =========================================== Advice on Endura straightning: HYDRAULICS and DYNAMICALLY-Stable Mechanical capture. Push-to-yield in middle of bow while each bowed-end is buck-held. |
These bumpers are really durable...Believe it or not, letting the full weight of my truck down on the bumper in the photo above had absolutely no effect at all. The bumper held the truck up easily. Had to use another idea that I got from one of the members here... The photo with the pipe and chain did work for another problem though!
Me thinks the 4X6 was not sufficient. I would have needed an Iron I-beam with the 4X6.
Actually, for the bowed lower bar, it was much easier than I was trying to make it. A fellow PY member gave me the idea......
The solution was to simply cut a small slit in the steel backing at the rear of the lower bar at the deepest bowed out area. Once that was done, the lower bar practically srang back into it's original shape. ONE light whack with a 4 lb hammer did the trick and all that was left was to weld the slit back up. Good as new.
Hmmmmm. THAT bit if information would have been better served WHEN I NEEDED IT!
Ask and ye shall receive....lol
Body Shop Section has an Endura Repaint Thread. That thread has motivated me to re-consider an Endura re-do. In Summary I would:
1. Remove & CONSIDER cut & straighten the Lower Bar, re-weld. 2. SandBlast to reach an all Endura surface. 3. Fill with some sort of Black rubber junk. 4. Spray SEM Gloss Black everywhere. 5. Sand by hand. 6. Go to Step 4 ! Be stuck in Major do-loop until results is smooth. Seems impossible to get a Bare Endura surface optically smooth. Me thinks the Metal Bar needs the Endura Rubber RECAST in a precision Bumper Mold. |
