Wiring diagram
Can anyone help me with a wiring diagram of my 70 gto.. I'm searching wires for a short.. Thanks
1979 Pontiac Trans Am - 403 auto 1970 Pontiac GTO (sold) |
diagram is in your factory service manual.
I dont own a service manual, but if someone has one and can send a copy of the diagram I would be very thankful...
suggest you purchase a manual as they are invaluable when working on vintage cars like ours. It is available on CD or paper. Best money ever spent.
jon,
here you go... http://216.178.81.108/forums/showthr...wiring+diagram david p.s. i don't have a manual, either. but there are some members here that will share the info with you. |
Very nice of you to search & post, David
Carlos |
Thanks David, I tried to search this but came up empty.. Thanks again..
Since someone was kind enough to load it, I colored it in.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
Nice, just color right rear turn/brake dark green.
Might confuse some folks.
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
The full size image is at: http://www.racerboy.net/images/cars/...iagram_clr.bmp
Dark green wire is labled right before it changes colors.
Is this right? Is the label wrong too b/c it says 'YLW"
Below the rectangle block (where you didn't change colors) is labled dark green, all the way back to the turn signal switch.
But yes you're getting there, just change the 'YEL' to 'Dk Green' in that one section. Edit, Looking back at the original black and white diagram the wires were mislabled in the section in question.
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty Last edited by "QUICK-SILVER"; 06-21-2009 at 03:37 PM. Reason: terrible spelling |
How's this? I made the same change to full-size one as well.
one more time with feeling...
