Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Strange Mitsubishi DLP problem
The volume goes to max by itself as soon as the set is turned on. You can't lower the volume with the remote, but you can with the front panel. I removed the batteries from the remotes as well.
A few months back we had an issue with volume control as well. It couldn't be changed by any control. I don't know what happened but it started working again about a week- ten days later. I read somewhere, but can no longer find it, there is a way to disconnect the front panel controls and the problems may disappear. I'm ok with that, I only use the remote anyway. I'm open to most suggestions.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson "If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams Right and wrong doesn't need facts all the time. -Lighthouseman ("lawyer") Starnes Performance Automatics www.Starnesperformance.com |
cant help but an alternative is removing the sound from the tv and using surround sound for audio
aaaargh |
That's what I'm doing for now. I can disconnect the internal speakers, but the remote still won't work.
FYI, search the net for problems with Mitsubishi DLP TV's. I have one too...it's a piece of schiese. My 35" Mitsubishi tube is 9 years older and is still great. Mitsubishi will help out after repeated complaints. Good luck!
All of my cars are Hybrids...they burn gas and rubber! '73 Ventura, Spotts 462 roller 10.785 @ 122.79, 1.507 60 ft 2850 lbs. plus driver, 3150 race weight '69 Firebird Convertible, Spotts 455 with long branches 12.561 @ 107.62, best on old 455 4290 race weight '72 Formula 455 HO numbers matching auto, work in progress! |
Once again, it fixed itself. It acted like the volume up button was stuck, but suddenly it works fine. I'll live with it for a few more years, since the picture is awesome.
I recommend no one buys a 65"+ DLP. The other tv's in your house immediately shrink up, look tiny and cheap.
Does your model show the volumn level in the screen?
Does it increase, like if you where holding the button or does it go full instantly? If it's like holding the button, the switchs do become intermitten. Depending on your model the remote sensor maybe on the same circuit board as the switchs. If it is, you can't unhook the cable. Call Mitsubishi and get a copy of the service manual. This will show you how to get to the switchs. Remove the vol up switch. If the remote sensor is in a different location, look in the TV and find the cable that runs to the small circuit board containing the switchs and disconnect it. |
