Q-Jet Secondary Choke Pulloff with Adjustment:
Can anyone give me a source and/or part number for the Q-Jet adjustable secondary choke pulloff with only ONE groove for rod attachment????
The correct varient will have a spring loaded screw in the pod for adjustment of travel. Thank you!!!!...Robert |
Robert, we don't use or install them here unless it's for a frame off show car or perfect restoration.
I've got at least 3 or 4 five gallon buckets full of them, some are excellent if not near new condition, we don't throw anything away!....Cliff
What carb-#?
There is at least 10 if not 20 varations of that style to choose from. Standard Motor Products. Inc. (Hygrade) is one source. |
Cliff,
I would like to find a 'pretty' one with the adjuster screw and the single groove...Robert Kenth: Not sure of a carb number as my application didn't have one like this...Robert |
Robert, I will have them, we never throw those away from many hundreds of cores I've used. I'll take a look over the weekend and pick out a nice one for you.....Cliff
I also need one of those travel limiting secondary dividers. What I like about the adjustable secondary pulloff is it allows me more adjustability of the choke pulloff rate during cold starts...Robert |
