Frame numbers
I searched and searched on the TOP of my 68 frame and couldn't find the VIN or any other numbers. Then I came across this photo in another thread that shows some numbers on the side. Is this the VIN etc location?
The #'s on the side should be the frame's part #.
The vin should be on the top rail fairly close to that location, some times rust pitting makes it hard to read them. |
I've got two 68 frames and the VIN is not visible. I'd like to at least confirm they are GTO frames (vs Chevy etc). Will the part number help confirm that?
...cars were meant to have bugs in the grill. |
Yes it will match a vin# on a GTO.
For 1968 the vin would be stamped on the top of the frame above the part number, build date, and plant code stamped on the side of the frame as seen in the photo posted.
Often the vin is in a smaller font than the side stampings plus rust pitting makes the vin stamp very hard to find. Wire brush the top area and then use some baby powder or chalk to cover the top of the frame. Then wipe off excess and hopefully the powder will settle into the stampings to find the vin. The vin stamp should read 28R100001 for a Pontiac, 68, Arlington, V8, first car. A Chevy would start with a 1, Olds 3, and Buick 4. |
Your car looks awesome. The VIN is not there, the rust is just too heavy. Can I tell by the frame "part number" if it's a Pontiac frame (vs Chevy, Olds etc)?
That is a question I do not know the answer to but I'd love to find out. I could check the part numbers on some of my loose frames and see if they are the same.
On a rust (and undercoat) free car you can read the VIN with a dentist type mirror without removing the frame. rubbing a bit of baby powder on the area helps bring up the contrast.
Good question about if the frame model number offers any info about the car make, I would think not since the frame was the same on different A bodies but if the motor mounts are included in the frame assembly we might be lucky. I will post the numbers on the frames I can read clearly along with the car info on this thread.
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
69 GTO convertible (Fremont car-early july 69 build date)
upper: 943347 S 213 (the S is in a circle and the tailpipe hanger bracket may be blocking the front part of the number) lower: 6-13 01 XL I will post others as I get to them
In that example, how do you read the date?
69 GTO 400, 4-Speed, Matador Red 69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack 72 Trans Am, 455HO, 4-Speed, Lucerne Blue 73 Trans Am, SD-455, 4-Speed, Brewster Green 73 Formula, 455, 4-Speed, Ascot Silver 73 Formula, 455, Navaho Orange Survivor |
I do not know, maybe june 13th in the lower line
